- Thank you received: 2181
Сustomization QTvcp
6 years 6 months ago #164606
Replied by cmorley on topic Сustomization QTvcp
Here is proof of concept.
I modified qtdragon.ui and qtdragon_handler.py
When you switch tabs it automatically moves the plotter to the right spot by calling the function switch()
The special widget is called widgetswitcher.
- hottabich
- Thank you received: 96
6 years 6 months ago #164608
by hottabich
Replied by hottabich on topic Сustomization QTvcp
Thank you very much!!! You are the best !!
- hottabich
6 years 6 months ago - 6 years 6 months ago #164774
by hottabich
(net btn_probesim motion.probe-input qtdragon.btn_probesim).
Created the btn_probesim button in qtdragon_postgui.hal added (net qtdragon.btn.0.probesim => motion.probe-input). Motion.probe-input does not work, qtdragon.btn_probesim works. Please tell me what's wrong? Excuse for troubling. The question is closed. Everything is working. In qtdragon_postgui.hal addedcmorley wrote: Get a button to call this function when pressed and released.
Code:def SimProbeButton(self, state): if state: hal.set_P('motion.probe-input','1') else: hal.set_P('motion.probe-input','o')
Last edit: 6 years 6 months ago by hottabich.
6 years 6 months ago #164874
Ok if you use your solution then you don't need the'SimProbeButton' function I posted
Your probe tab looks good!
Chris
Chris
- hottabich
6 years 6 months ago - 6 years 6 months ago #164950
by hottabich
Hello Chris! I resized qtdragon to 1900x1000, which turned out to be an interesting option for
fullHD monitor owner. I want to add widgetswitcher to the Status page, but it will be the second in the interface. I could not get. Is it real or impossible?
6 years 6 months ago #165040
Should be possible. I'm working out of town for a few days...so cant help at the moment.
The following user(s) said Thank You: tommylight, hottabich
Time to create page: 2.794 seconds
