Сustomization QTvcp
6 years 6 months ago #164410 by cmorley
Replied by cmorley on topic Сustomization QTvcp
It's a error because qtdragon tried to do something that it cannot do.
How did you cause it?
6 years 6 months ago #164411 by hottabich
Replied by hottabich on topic Сustomization QTvcp
I registered self.w.mditouchy.run_command () in qtdragon_handler. Section init_widgets (self):
6 years 6 months ago #164412 by cmorley
yes no good.
you must call self.w.mditouchy.run_command () only when the MDI command is to be run.
To make the cycle start button run MDI, Try this (I didn't test it):
def btn_start_clicked(self): if STATUS.is_mdi_mode(): self.w.mditouchy.run_command() return if self.w.main_tab_widget.currentIndex() != 0: return if not STATUS.is_auto_mode(): self.add_alarm("Must be in AUTO mode to run a program") return self.w.btn_start.setProperty('running', True) self.w.btn_start.setStyle(self.w.btn_start.style()) start_line = int(self.w.lbl_start_line.text().encode('utf-8')) self.add_alarm("Started program from line {}".format(start_line)) ACTION.RUN(start_line)
6 years 6 months ago #164415 by hottabich
Thanks It works!! I’ll check in more detail later. Unsubscribe if something is wrong. Thanks again!!!
6 years 6 months ago #164585 by hottabich
Hello! Checked the work of MDITouchy widgets. All is well. I can not only implement the Macro tab. How does it work, tell me please.
Thank you for your hard work.
6 years 6 months ago #164588 by cmorley
What is the problem with macro tabs - I thought that was working already.
Time to create page: 0.774 seconds
