Сustomization QTvcp
6 years 6 months ago #164233 by cmorley
Replied by cmorley on topic Сustomization QTvcp
Can you add -d to INI change :
[DISPLAY]
DISPLAY = qtvcp -d qtdragon
Start the screen load with button/dialog , shut down and post the log file:
dtdragon.log should be in the config directory.
Then do again loading with the tab file manager and then post the log file again.
Hopefully I can see a difference. It could be a language conversion problem - I wouldn't see that problem on my computer.
Chris
6 years 6 months ago - 6 years 6 months ago #164237 by hottabich
Replied by hottabich on topic Сustomization QTvcp
Here's what happened. Why is the mistake in Russian? Maybe translate the translator
to English? Or all Linux Debian to change the language. In english too Error.
Last edit: 6 years 6 months ago by hottabich.
6 years 6 months ago #164256 by tommylight
Replied by tommylight on topic Сustomization QTvcp
Check what file it is trying to open on startup, it should be in the ini file as
open_file=xxxxxxx
6 years 6 months ago #164262 by hottabich
OPEN_FILE = "" So it was I commented did not help. Qt Axis default doesn’t load anything here you can do this, but it is very annoying.
6 years 6 months ago #164263 by tommylight
I can read Russian quite good, so it is saying that it can not find the folder
/home/jura/linuxcnc/nc_files
Somewhere in the configuration files it has an entry for opening something from there, or might need adding / at the end of that line.
6 years 6 months ago - 6 years 6 months ago #164266 by hottabich
Correctly he searches for a sung path lies the hazzy file and all the rest.
OPEN_FILE = blank.ngc is ignored. And so that by default nothing is loaded, how can one do this in Qt axis?
Time to create page: 0.349 seconds
