Сustomization QTvcp
6 years 6 months ago #164046 by cmorley
Replied by cmorley on topic Сustomization QTvcp
macrotab is fixed
6 years 6 months ago #164047 by hottabich
Replied by hottabich on topic Сustomization QTvcp
I use macrotab the one that you edited before after updating linuxcnc macrotab did not work for me. Please post corrected.
6 years 6 months ago #164048 by cmorley
change macro_widget.py to
def _hal_init(self): self.runButton.setEnabled(False) STATUS.connect('state-off', lambda w: self.runButton.setEnabled(False)) STATUS.connect('state-estop', lambda w: self.runButton.setEnabled(False)) STATUS.connect('interp-idle', lambda w: self.runButton.setEnabled(STATUS.machine_is_on() and (STATUS.is_all_homed() or INFO.NO_HOME_REQUIRED))) STATUS.connect('interp-run', lambda w: self.runButton.setEnabled(False)) STATUS.connect('not-all-homed', lambda w, axis: self.runButton.setEnabled(False or INFO.NO_HOME_REQUIRED)) STATUS.connect('all-homed', lambda w: self.runButton.setEnabled(True)) STATUS.connect('general',self.returnFromDialog)
6 years 6 months ago - 6 years 6 months ago #164049 by hottabich
Thank you so much!!!
Last edit: 6 years 6 months ago by hottabich.
6 years 6 months ago - 6 years 6 months ago #164116 by hottabich
Load dialog action. Load file all OK. Exit. Start error: file ended without a percent sign. Maybe because there is still a file manager? File manager all OK.Please, your advice.
6 years 6 months ago #164124 by tommylight
Replied by tommylight on topic Сustomization QTvcp
Gcode file needs % sign at the beginning and at the end.
Time to create page: 2.114 seconds
