- Thank you received: 96
Сustomization QTvcp
- hottabich
actual speed value on the button.
- hottabich
as exit, Home_All button green, the interface is active but does not work like that. How to fix please tell me.
- Thank you received: 2181
- hottabich
You can use linuxcnc without homing, but it is not recommended.
starting with x0 y0 z0:
from documentation:
POSITION_FILE = position.txt - If set to a non-empty value, the joint positions are stored between runs in this file. This allows the machine to start with the same coordinates it had on shutdown. This assumes there was no movement of the machine while powered off. If unset, joint positions are not stored and will begin at 0 each time LinuxCNC is started. This can help on smaller machines without home switches. If using the Mesa resolver interface this file can be used to emulate absolute encoders and eliminate the need for homing (with no loss of accuracy). See the hostmot2 manpage for more details.
in [TRAJ] header remove POSITION_FILE=
- hottabich
no and the interface is locked. Qtaxis also works.
