Сustomization QTvcp
6 years 6 months ago #164293 by tommylight
Replied by tommylight on topic Сustomization QTvcp
cmorley wrote:
tommylight wrote: Check what file it is trying to open on startup, it should be in the ini file as
open_file=xxxxxxx
qtvcp doesn't currently support preloading programs.
Did not know that, thank you for clarifying.
6 years 6 months ago #164294 by cmorley
Replied by cmorley on topic Сustomization QTvcp
Please remind me what distribution you are using.
6 years 6 months ago #164298 by cmorley
I see some weirdness:
your log:
2020-04-17 09:54:48,769 - QtDesigner.QTVCP.QT_ACTION - INFO - Homing Joint: -1
2020-04-17 09:54:51,614 - QtDesigner.QTVCP.QT_ACTION - DEBUG - Load program /home/jura/linuxcnc/nc_files
2020-04-17 09:55:05,914 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Show
2020-04-17 09:55:08,740 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Button pressed is: &Yes
2020-04-17 09:55:08,741 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Hide
2020-04-17 09:55:08,742 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Value of pressed button: 16384
2020-04-17 09:55:08,845 - QTvcp.QTVCP.QT_MAKEPINS - INFO - Closing cleanup on: basicprobe
2020-04-17 09:55:08,846 - QTvcp.QTVCP.WIDGETS.BASIC_PROBE - DEBUG - Saving Basic Probe data to preference file.
Mine:
2020-04-17 11:57:56,248 - QtDesigner.QTVCP.QT_ACTION - INFO - Homing Joint: -1
2020-04-17 11:58:03,842 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Show
2020-04-17 11:58:14,314 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Hide
2020-04-17 11:58:14,314 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Saving FileDialog-geometry data from widget screen_options to file.
2020-04-17 11:58:14,456 - QtDesigner.QTVCP.QT_ACTION - DEBUG - Load program /home/chris/linuxcnc/nc_files/hazzy.ngc
2020-04-17 11:58:14,502 - QTvcp.QTVCP.WIDGETS.GCODE_GRAPHICS - DEBUG - load the display: /home/chris/linuxcnc/nc_files/hazzy.ngc
2020-04-17 12:03:12,493 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Show
2020-04-17 12:03:14,039 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Button pressed is: &Yes
2020-04-17 12:03:14,040 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Hide
2020-04-17 12:03:14,040 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Value of pressed button: 16384
2020-04-17 12:03:14,139 - QTvcp.QTVCP.QT_MAKEPINS - INFO - Closing cleanup on: basicprobe
2020-04-17 12:03:14,140 - QTvcp.QTVCP.WIDGETS.BASIC_PROBE - DEBUG - Saving Basic Probe data to preference file.
Notice how your's loads the program before the overlay is shown or hidden and before the yes button is pressed.
Also your is missing the actual program name so it can't be actually loading a program I would think.
Chris
6 years 6 months ago #164301 by cmorley
hottabich wrote: Found where the error is. How are you Chris with this file, load_dialog_action save in
examples and then there he searches for the error too.
Ahh yes I get it now in qtdragon it does preload a program!
I didn't have 'reload program' option selected that is why i didn't get the error.
6 years 6 months ago #164302 by cmorley
In dialog_widget.py line 532 change to:
if fname and not return_path: if self.PREFS_: self.PREFS_.putpref('last_file_path', fname, str, 'BOOK_KEEPING') ACTION.OPEN_PROGRAM(fname) STATUS.emit('update-machine-log', 'Loaded: ' + fname, 'TIME') return fname
Should store the program name properly
Chris
6 years 6 months ago #164303 by tommylight
Now i am confused ! :)
All is good, i will continue to monitor from a distance.
Time to create page: 2.582 seconds
