- Thank you received: 2181
Сustomization QTvcp
6 years 6 months ago #164040
Replied by cmorley on topic Сustomization QTvcp
If you don't want to home then why not remove the button?
6 years 6 months ago #164041
It should not glow green - the machine is not homed.
NO_FORCE_HOMING = 1 does not mean linuxcnc starts already homed.
It means you are not required to home to run MDI or programs.
- hottabich
- Thank you received: 96
6 years 6 months ago #164042
by hottabich
Replied by hottabich on topic Сustomization QTvcp
The button indicates that the machine is ready for use! Yes the car is not homed!
6 years 6 months ago #164043
remove the button - it's useless if you are not going to home
6 years 6 months ago #164044
In the handler file try:
def initialized__(self):
self.set_dro_homed(True)
- hottabich
6 years 6 months ago #164045
by hottabich
Without homed, it is necessary when processing large files in case of emergency stop, but otherwise the traditional mode. Can macrotab be fixed?
Time to create page: 0.414 seconds
