- Thank you received: 96
Сustomization QTvcp
- hottabich
6 years 6 months ago - 6 years 6 months ago #164127
by hottabich
Replied by hottabich on topic Сustomization QTvcp
The same file downloaded through the file manager is OK.
In other Qtvcp interfaces, the Load dialog action does not display the error of the same files.
Typically, the file ends with M2.
Last edit: 6 years 6 months ago by hottabich.
- Thank you received: 2181
6 years 6 months ago #164165
Replied by cmorley on topic Сustomization QTvcp
i don't know where to start. I tried your hazzy program and it loads fine here.
When you load the file, does it the gcode look right?
Have you loaded a macro before loading the program?
- hottabich
6 years 6 months ago - 6 years 6 months ago #164188
by hottabich
I added action button load_dialog_action in qtdragon. When downloading a file through a pop-up window, I get an error. File Manager from the page
File uploads work well. Why is that? See post 164116, 164127.
6 years 6 months ago #164197
ok great I'll check it out.
6 years 6 months ago #164200
Using your qtDragon files, hazzy.ngc loads fine both ways for me.
Are you sure you are loading the same hazzy.ngc file both ways?
Chris
Chris
- hottabich
6 years 6 months ago - 6 years 6 months ago #164232
by hottabich
The hazzy.ngc file for an example with percent at the end of the file. This happens with all files. Start qtdragon, load_dialog_action, cycle start, all OK. Exit qtdragon,
start qtdragon, clicked Home All Error: file ends without a percent sign, but he is.
File manager, Load, all OK. See screenshot
Time to create page: 0.825 seconds
