- Thank you received: 2181
Сustomization QTvcp
6 years 6 months ago #165465
Replied by cmorley on topic Сustomization QTvcp
Try this:
I edited the handler and .ui files
Chris
Chris
- hottabich
- Thank you received: 96
6 years 6 months ago - 6 years 6 months ago #165495
by hottabich
Replied by hottabich on topic Сustomization QTvcp
Thank you so much!!! Everything is working. I removed the blank page, it might work for someone. And why does the designer not add the widget to the UI file? The QTDragon interface is almost ready to go. Thank you and Jim for the great interface.
and your hard work.
and your hard work.
Last edit: 6 years 6 months ago by hottabich.
6 years 6 months ago #165500
i just pushed work so that mdi_touchy supports INI base macros.
The sample Qttouchy config should demonstrate use.
Chris
Chris
- hottabich
6 years 6 months ago - 6 years 6 months ago #165622
by hottabich
Qttouchy does not start. What is wrong with me? And I’m very embarrassed, but I can’t implement SimProbeButton from your post, please explain how to do this. Thank.I also changed a little mdi_touchy.widgets it seems to me that for a touch monitor it will be better than you think.
6 years 6 months ago #165623
You reported that it did work. I'm confused.
hottabich wrote:
Created the btn_probesim button in qtdragon_postgui.hal added (net qtdragon.btn.0.probesim => motion.probe-input). Motion.probe-input does not work, qtdragon.btn_probesim works. Please tell me what's wrong? Excuse for troubling. The question is closed. Everything is working. In qtdragon_postgui.hal addedcmorley wrote: Get a button to call this function when pressed and released.
Code:def SimProbeButton(self, state): if state: hal.set_P('motion.probe-input','1') else: hal.set_P('motion.probe-input','o')
(net btn_probesim motion.probe-input qtdragon.btn_probesim).
- hottabich
6 years 6 months ago #165625
by hottabich
It works correctly, but I can’t get the second probe sim button on the status page. I write probesim_button_2-clicked-probesim_button-click in the designer. But the probesim_button_2 button does not work. A simple question but the brain is boiling and nothing happens.
Time to create page: 0.628 seconds
