Сustomization QTvcp
6 years 6 months ago #165627 by cmorley
Replied by cmorley on topic Сustomization QTvcp
You have two button to simulate probing?
To connect two button to one probe pin requires either a AND component to allow the two button pins to drive the same probe input....
or use qtvcp to set the probe pin directly.
The function I posted sets the pin directly and can be called by many buttons.
This describes how to designer slots to call the function:
linuxcnc.org/docs/2.8/html/gui/qtvcp.htm...dgets_to_python_code
You could also use action button python command option to call the function.
I'll look at you mdi_touchy changes
6 years 6 months ago - 6 years 6 months ago #165638 by hottabich
Replied by hottabich on topic Сustomization QTvcp
The issue was resolved in a radical way. Removed two buttons and added one working
the bottom panel is now accessible from all pages. Thanks for the science and
please excuse the concern.
Last edit: 6 years 6 months ago by hottabich.
6 years 6 months ago #165751 by hottabich
In order for QTTouchy to work, you need to register HALFILE = /usr/share/linuxcnc/hallib/check_xyz_constraints.hal in the INI file.
6 years 6 months ago - 6 years 6 months ago #165970 by hottabich
According to the description of mditouchy.widgets I rule qttouchy.ini, in nc files I create
macros folder with increment.ngc. Starting qttouchy I click on the MACRO tab and nothing happens. What's wrong?
6 years 6 months ago #166050 by cmorley
add to INI, under [DISPLAY]
MACRO=increment xinc yinc
make sure this points to the folder with the macro:
PROGRAM_PREFIX = SOMEPLACE/macros/
6 years 6 months ago #166113 by hottabich
So in the attached INI file is this all there or am I misunderstanding something?
Time to create page: 2.496 seconds
