- Thank you received: 7491
Сustomization QTvcp
6 years 5 months ago #169305
Replied by tommylight on topic Сustomization QTvcp
Sim do not like jogging before homing.
Open sim, home all, then jog.
- hottabich
- Thank you received: 96
6 years 5 months ago #169313
by hottabich
Replied by hottabich on topic Сustomization QTvcp
Thanks for the tip! When working with the machine, this is not observed. Excuse for troubling.
- hottabich
6 years 4 months ago #170487
by hottabich
Hello! In the latest edition of QtDragon, replace the qtdragon_dark.qss file with the attached one. It will become like in the screenshot.
- hottabich
6 years 1 month ago #182511
by hottabich
It seems like a simple task but I can't do it. I decided to add Fullscreen in QtDragon. Please tell me what I'm doing wrong? As a sample I took from x1mill.
- Thank you received: 2181
6 years 1 month ago #182609
Replied by cmorley on topic Сustomization QTvcp
Seems the error indicates there is a layout missing.
The widget that gets moved must be in a layout in the original position.
The layout is a placeholder so the moved widget can go back in the same place.
- hottabich
6 years 1 month ago - 6 years 1 month ago #182638
by hottabich
Thanks for your attention! As I understand it, you need to correctly specify the path gcode_graphics in widgetswitcher (widget_list). I do everything the same way with x1mill. But it doesn't work. Here is the code in the handler: x1mill
or qtdragon
plus sceenshot. Probably wrong with the panels, I'll figure it out. So it happened, made a hybrid x1mill + qtdragon, fixed it.
def full_screen(self, state):
if state:
self.w.stackedWidget_0.setCurrentIndex(1)
self.w.widgetswitcher.show_id_widget(1)
else:
self.w.stackedWidget_0.setCurrentIndex(0)
self.w.widgetswitcher.show_id_widget(0)
if state:
self.w.stackedWidget_2.setCurrentIndex(1)
else:
self.w.stackedWidget_2.setCurrentIndex(0)
Last edit: 6 years 1 month ago by hottabich.
Time to create page: 0.864 seconds
