INFO and DEBUG messages
- phillc54
- Thank you received: 2100
15 Sep 2020 21:41 - 15 Sep 2020 21:42 #182322
by phillc54
INFO and DEBUG messages was created by phillc54
Is there a way to prevent the displaying of INFO and DEBUG messages like the below when embedding Qtcvp into Axis?
Last edit: 15 Sep 2020 21:42 by phillc54.
- Thank you received: 2181
15 Sep 2020 21:53 #182325
Replied by cmorley on topic INFO and DEBUG messages
How were u loading it?
- phillc54
15 Sep 2020 21:55 #182326
by phillc54
Replied by phillc54 on topic INFO and DEBUG messages
like so:
[DISPLAY]
EMBED_TAB_NAME = Camera
EMBED_TAB_COMMAND = halcmd loadusr -Wn qtvcp_embed qtvcp -d -c qtvcp_embed -x {XID} cam_alignPlease Log in or Create an account to join the conversation.
15 Sep 2020 22:02 #182327
Take the -d out and see how much that helps.
- phillc54
15 Sep 2020 22:09 #182329
by phillc54
No apparent difference. It is not a showstopper, just a lot of unnecessary (if not debugging) messages.
Apparently I also need some MDI commands to go with this screen. Any hints on where to find them and how to apply them?
15 Sep 2020 22:41 #182333
surprisingly this was answered here recently:
forum.linuxcnc.org/qtvcp/40032-qtvcp-cam-view-dialog?start=0
- phillc54
15 Sep 2020 22:54 #182334
by phillc54
Thanks Chris, my search foo is brokensurprisingly this was answered here recently:
- phillc54
15 Sep 2020 23:10 #182337
by phillc54
Is it possible to read the rotation of the crosshairs so we could add a rotation to the origin.
15 Sep 2020 23:20 #182339
I haven't tried it but you could add a custom handler file in your config folder to extract the rotation (self.rotation) and send it out as a HAL pin. Would that work?
It's easier to do these things if using a QT based screen (Don't need to use a HAL pin)
- phillc54
15 Sep 2020 23:29 #182344
by phillc54
I am wary of making a real screen until the Python3 changover is complete.
I think that would be OK, this is just someting I am toying with at the moment.I haven't tried it but you could add a custom handler file in your config folder to extract the rotation (self.rotation) and send it out as a HAL pin. Would that work?
Yes, I imagine it would be, one day...It's easier to do these things if using a QT based screen (Don't need to use a HAL pin)
Time to create page: 0.632 seconds
