INFO and DEBUG messages
- Thank you received: 2181
16 Sep 2020 19:50 #182488
Replied by cmorley on topic INFO and DEBUG messages
There is horizontal spacer added to push all the other widgets to the left.
If you add to the right of it , it's pushed to the right.
try:
self.w.horizontalLayout.insertWidget(5,self.w.rotate_degrees)
try:
- phillc54
- Thank you received: 2100
16 Sep 2020 20:08 #182491
by phillc54
Replied by phillc54 on topic INFO and DEBUG messages
Perfect!
I saw the horizontal spacer in the ui file but it appeared to be on a different level.
Attached is my end result, many thanks...
16 Sep 2020 22:13 #182495
Oh hey that's great - maybe I should incorporate this behavior in the stock panel.
- phillc54
16 Sep 2020 22:16 #182497
by phillc54
It is handy for fine tuning...
One thing I did notice is that I use the angle from the camera-rotation pin in a G10 L2 P0 R#<_hal[camera.cam-rotation]> command to set the coordinate sytem XY rotation then it is reversed to what it should be. I changed the line in the NextFrame function to:
self.pin_.set(360 - self.w.camview.rotation)Please Log in or Create an account to join the conversation.
16 Sep 2020 22:18 #182498
That seems a good idea.
Maybe I should wait till you improve it some more!
- phillc54
16 Sep 2020 22:23 #182499
by phillc54
I think it is where I like it now, looking good. I'll finish testing on the plasma table after lunch.
The PlasmaC config doesn't require any Z motion which is why I hid the Z dro label. It embeds into Axis really well. I'll post any other changes here if I make any.
- phillc54
16 Sep 2020 23:57 #182502
by phillc54
This is my end result which works well for me.
Basically the same as before but I hijacked the mouseDoubleClick function to allow resetting the scale and circle diameter.
I made a couple of changes to to camview_widget.py and cam_align.ui as well.
Thanks again for pointing me in the right direction.
18 Sep 2020 00:30 #182610
When I get a chance I will see about incorporating these changes in to linuxcnc.
- phillc54
18 Sep 2020 00:47 #182612
by phillc54
I am working on another...
A button labelled "Mark Edge":
move crosshair to a point on an edge that intersects the material origin
press button, label changes to "Mark X0 Y0"
move crosshair to the material origin
press button, label changes to "Mark Edge"
crosshairs rotate if thes actions caused a rotation
press original SET Origin to set the origin etc. etc.
It works in a sim, just confirming it on my machine.
- phillc54
18 Sep 2020 04:06 #182624
by phillc54
Attached is the latest incarnation.
Time to create page: 0.105 seconds
