INFO and DEBUG messages
15 Sep 2020 23:48 #182350 by cmorley
Replied by cmorley on topic INFO and DEBUG messages
Try this:
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
16 Sep 2020 00:18 #182359 by phillc54
Replied by phillc54 on topic INFO and DEBUG messages
Try this:
Brilliant...:)
It works a treat, now for some fine tuning. Thanks Chris.
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 00:57 #182370 by phillc54
I think lines 131 and 147 of cam_align.ui have the incorrect axes.
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 02:04 - 16 Sep 2020 02:24 #182392 by phillc54
Chris, sorry to be a pain but I was under the impression it was possible to change a variable from the handler file. Something along the lines of changing self.rotationIncrement in camview_widget.py by having CAM.rotationIncrement = .1 in the initialized__ or class_patch__ function of the handler. Am I on the right track or just kidding myself...
Edit: I found it, self.w.camview.rotationIncrement
Last edit: 16 Sep 2020 02:24 by phillc54.
16 Sep 2020 18:59 #182480 by cmorley
Did you figure out how to do what you want?
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 19:07 #182481 by phillc54
Almost, my only remaining issue is that from the handler file I am trying to add a QPushButton to the horizontalLayout. I have established that the widget is created as I can read the size of it but I haven't managed to get it to "show".
After iteration 1562 I have:
        self.w.rotate_degrees = PBUTTON('TEST')
        self.w.rotate_degrees.resize(self.w.rotate_degrees.sizeHint())
        self.w.rotate_degrees.clicked.connect(self.rotation_changed)
        self.w.horizontalLayout.addWidget(self.w.rotate_degrees)
        self.w.rotate_degrees.show()
        print 'SIZE:', self.w.rotate_degrees.size()
And it is there but it is not. :(
16 Sep 2020 19:19 #182482 by cmorley
see if this works for you.
But you could also edit a copy of the ui file and add it to your config file, if that is easier. (you would need to set up designer to find Qtvcp libraries though)
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 19:25 #182483 by phillc54
Thank Chris, that is pretty well what I have now and behaves the same.
Yes, I have it working with a hand edited version of the ui file but I was hoping to do it with just the handler file and now I just can't let it go.
16 Sep 2020 19:30 #182484 by cmorley
It works for me - is the button just hidden because the window isn't large enough?
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 19:36 #182486 by phillc54
:blush:
Well that is embarrassing...
I don't understand the large gap between the last label and the new button.
Time to create page: 0.131 seconds
