INFO and DEBUG messages
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Sep 2020 02:11 #182828 by phillc54
24 May 2021 08:26 #210057 by zu4lu
Replied by zu4lu on topic INFO and DEBUG messages
Hop it is the correct thread. Is it possible to asigne a specific camera?
24 May 2021 13:03 #210088 by cmorley
Replied by cmorley on topic INFO and DEBUG messages
Currently , no.
How would you imagine is a good way to select cameras?
24 May 2021 23:26 #210181 by zu4lu
No idea. Problem is, i have 2 cams and need them(the second for overviewing the milling process). For longer jobs the cam for touch off disappears and has to be restarted in linux with usbreset. Kernel gives then a higher video number and i have to reboot to correct this. So i made a symlink with udev, you see the problem? Maybe somthing like the old camview.py:
" if you want special setting of your camera on start up, you can supply a command through the properties something like this:
v4l2-ctl -d /dev/video1 -c exposure_auto=1 -c exposure_auto_priority=0 -c exposure_absolute=10
it sets for your second camera (/dev/video1), the shutter time to manual settings and changes the shutter time to 10 ms.
see v4l2-ctl --help for more details"
25 May 2021 00:17 #210185 by cmorley
Someone else asked a similar question:
forum.linuxcnc.org/qtvcp/42654-how-to-ch...ce-used-by-cam-align
Would that help? or do you need a way to do it without closing the panel?
The following user(s) said Thank You: zu4lu
25 May 2021 00:56 #210191 by zu4lu
Thank you, i change the thread ;-)
