INFO and DEBUG messages
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
16 Sep 2020 02:41 - 16 Sep 2020 02:42 #182322 by phillc54
INFO and DEBUG messages was created by phillc54
Is there a way to prevent the displaying of INFO and DEBUG messages like the below when embedding Qtcvp into Axis?
File Name: qtvcp-messages.txt
File Size:5 KB
Last edit: 16 Sep 2020 02:42 by phillc54.
16 Sep 2020 02:53 #182325 by cmorley
Replied by cmorley on topic INFO and DEBUG messages
How were u loading it?
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 02:55 #182326 by phillc54
Replied by phillc54 on topic INFO and DEBUG messages
like so:
[DISPLAY]
EMBED_TAB_NAME          = Camera
EMBED_TAB_COMMAND       = halcmd loadusr -Wn qtvcp_embed qtvcp -d -c qtvcp_embed -x {XID} cam_align
16 Sep 2020 03:02 #182327 by cmorley
Take the -d out and see how much that helps.
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 03:09 #182329 by phillc54
No apparent difference. It is not a showstopper, just a lot of unnecessary (if not debugging) messages.
Apparently I also need some MDI commands to go with this screen. Any hints on where to find them and how to apply them?
16 Sep 2020 03:41 #182333 by cmorley
surprisingly this was answered here recently:
forum.linuxcnc.org/qtvcp/40032-qtvcp-cam-view-dialog?start=0
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 03:54 #182334 by phillc54
Thanks Chris, my search foo is broken :blush:
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 04:10 #182337 by phillc54
Is it possible to read the rotation of the crosshairs so we could add a rotation to the origin.
16 Sep 2020 04:20 #182339 by cmorley
I haven't tried it but you could add a custom handler file in your config folder to extract the rotation (self.rotation) and send it out as a HAL pin. Would that work?
It's easier to do these things if using a QT based screen (Don't need to use a HAL pin)
  • phillc54
  • Platinum Member
  • Platinum Member
16 Sep 2020 04:29 #182344 by phillc54
I think that would be OK, this is just someting I am toying with at the moment.
Yes, I imagine it would be, one day...
I am wary of making a real screen until the Python3 changover is complete.
