- Thank you received: 2181
Error in tool_offsetview.py
3 years 2 months ago #279017
Replied by cmorley on topic Error in tool_offsetview.py
I pushed the changes for G90 and also added G20/21 to cover that case too.
Thank you!
Thank you!
- MarkoPolo
- Thank you received: 90
3 years 2 months ago #279018
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
Yes, it looks like the problem is solved. After initial testing, it works flawlessly.
If it stops working on the stop button, I see a log in the console, as in the screenshot. I suppose it's nothing important.
- MarkoPolo
3 years 1 month ago #280418
by MarkoPolo
Hi Chris.
I also reworked the icons for the A axis, I think it will be better for the consistency of the appearance of the buttons
- MarkoPolo
3 years 1 month ago #281659
by MarkoPolo
Lots of minor fixes for better alignment of elements, this time for qtdragon_hd.
We still need to correct the bar at the very bottom of the window, because it looks bad, but it is somehow strangely made and I think it is necessary to modify the service file.
3 years 1 month ago #281664
Looks like I haven't added your new A buttons either - can you confirm?
Marius, were you the one who modified qtdragon to be resizeable?
I was thinking having qtdragon_hd slightly resizeable would be nice too - I tried but it's a bigger jog then I have time for
Chris
Chris
- MarkoPolo
3 years 1 month ago #281667
by MarkoPolo
Yes, I confirm that you did not add the "A" buttons
Yes, I modified the qtdragon to make it stretchy.
It's a lot of work, in QT it's not that easy to make everything scale proportionally when changing size.
What range of values would you like qtdragon_hd to have?
Marek
Marek
Time to create page: 0.148 seconds
