- Thank you received: 90
Error in tool_offsetview.py
- MarkoPolo
3 years 1 week ago #283523
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
Yes, I use master. This solution using time.sleep(1.5) works very well. Maybe it will be useful to someone until the problem you are reporting on is resolved.
- snowgoer540
- Thank you received: 907
3 years 1 day ago #284153
by snowgoer540
Replied by snowgoer540 on topic Error in tool_offsetview.py
I just pushed a commit that should take care of this race condition. Feel free to remove the sleeps you've added to the handler, etc. and give it a try. Let me know if you see any issues.
- MarkoPolo
3 years 18 hours ago #284205
by MarkoPolo
Yes, now after updating to the latest version it works properly, without the need to delay GUI loading.
There is one more problem in gtdragon, possibly unrelated to the above problem. The 50% and 100% buttons next to the spindle speed slider do not work. I also checked version 2.9.1 running from the ISO installer and the same problem occurs.
- Thank you received: 2181
3 years 8 hours ago #284238
Replied by cmorley on topic Error in tool_offsetview.py
I pushed the fix to 2.9 - there is a conflict in master so I can't move it to there yet.
The two action button's property 'joint_number' needs to be set to 0 instead of -1
- MarkoPolo
2 years 11 months ago #285322
by MarkoPolo
Hi Chris.
I noticed that when I press the "go to sensor" button in the "offsets" tab
the entire screen is frozen, you can't see the speed or position progress in DRO. (in qtdragon, of course).
I corrected two lines in the handler file in the "btn_goto_sensor_clicked" function and it works fine.
Can you check if this is correct and make corrections if necessary?
Changes in the screenshot.
2 years 11 months ago #285467
Yes I think that change is fine - I'll do some more testing though.
Time to create page: 0.695 seconds
