- Thank you received: 2181
Error in tool_offsetview.py
2 years 3 months ago #306302
Replied by cmorley on topic Error in tool_offsetview.py
Well that masks the problem, and in some probing the spindle should be on.
But I agree we need to protect the user in the mean time.
This is one of those deep seeded, need to look at the big picture problems.
We aren't very good at those
2 years 3 months ago #306303
I can make it happen by:
MDI: M3 S100
manual stop spindle
MDI: M70
MDI: M72
Spindle starts.
MDI: M3 S100
manual stop spindle
MDI: M70
MDI: M72
Spindle starts.
- MarkoPolo
- Thank you received: 90
2 years 3 months ago #306435
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
For now, m5 solves the problem in my tool measurement procedure. I do not use the built-in qtvcp procedures. Let someone smarter figure out how to solve the problem, I probably can't help.
Returning to the topic of the axis buttons function. Could you add the "go to zero" function?.
I only added the titles to the axis_tool_button.py file to the screenshot. I do not have the functions working yet.
2 years 2 months ago #306864
yes.
I also have done some work on having the DRO clickable with similar options.
I think I will set it up as stylesheet options, so a user can change them fairly easily.
The following user(s) said Thank You: tommylight, MarkoPolo
2 years 2 months ago #306889
Ok that work is pushed to master now.
I have not updated the docs yet, but stylesheets can change the options.
The menu items in the DRO or axis selection buttons can be made the same or any combination of those options.
Also now you can recover from pressing the zero button by selecting 'set to last' in the dro widget menu options.
let me know what you think.
Chrs
Chrs
- MarkoPolo
2 years 2 months ago #306913
by MarkoPolo
I tested it a bit, it works very well.
I like it.
It could be everything even in one menu, axis button, but if it is possible to customize the content of both menus, it is very good.
How to do it in the style sheet?
In qtdragon_hd, the ref buttons are probably no longer needed? If so, I can customize the layout..
Marek
I like it.
Marek
Time to create page: 1.101 seconds
