Error in tool_offsetview.py
2 years 5 months ago #301178 by cmorley
Replied by cmorley on topic Error in tool_offsetview.py
Curious - AXIS uses the same code.
Could you add some prints to the code and see if system_memory_bytes get set differently on AXIS vrs QtDragon?
2 years 5 months ago #301181 by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
ah, ok. You're right, there is no preview in axis either. (first I doubled the value in glcanon.py and then checked in axis)
2 years 5 months ago #301257 by MarkoPolo
Chris. If the 20mb limit should remain, could you add an option to the ini that would disable this limitation?
I don't want to modify glcanon.py after every system update.
Another topic.
I'm looking for a reason why the progress bar doesn't work when loading a gcode file. In qtdragon_hd the progress bar works and the code seems to be the same as in qtdragon.
Could you check it?
(I'm not sure but the "updateProgress" function is not used at all, qtdragon_hd does not have this function)
2 years 5 months ago #301273 by cmorley
In case you are interested how this came along:
github.com/LinuxCNC/linuxcnc/pull/2896
In fact I said it should be set-able and then never followed up.
You must load very big files - do you see the bounding box show?
There is a signal missing from gcode_graphics to MainWindow - I'll add it back soon.
2 years 5 months ago #301321 by cmorley
Dragon loading progressbar should be fixed now.
[DISPLAY]
GRAPHICAL_MAX_FILE_SIZE = -1
Should allow maximize usage of  the memory for graphical display.
or set it to any integer MB of system memory (default would be 20 MB)
Should work with Qtvcp/GMoccapy/AXIS
Pushed to master
Chris
The following user(s) said Thank You: tommylight, MarkoPolo
2 years 5 months ago #301330 by MarkoPolo
Great. I tested it and everything works fine. Thanks
One more thing needs to be fixed and qtdragon will be completely usable...
Time to create page: 0.137 seconds
