- Thank you received: 2181
Error in tool_offsetview.py
2 years 5 months ago #299992
Replied by cmorley on topic Error in tool_offsetview.py
if axis.z.eoffset-enable in set false, do you get full speed again?
If so then I can set and unset it based on when the spindle raises.
At the moment it is set and never turned off.
Ok I'll try to remember to add some detail in the docs.
- MarkoPolo
- Thank you received: 90
2 years 5 months ago #300009
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
I do that. "halcmd setp axis.z.eoffset-enable FALSE" , the value changes to FALSE but the maximum speed remains unchanged.
2 years 5 months ago #300038
Looks like it can't be worked around, which does make aense. There needs to be vel/acc room for the external offsets to act.
In this case maybe you could up max velocity on z by 20 percent..as the external offsets will only be used while paused.
- MarkoPolo
2 years 5 months ago #300064
by MarkoPolo
It's not really a big problem for me, the feedrate of 7200 in the Z axis is completely sufficient, if I set the value "OFFSET_AV_RATIO=0.1" I have a feedrate of 8100 (and the spindle lifting speed is twice as low).
I'm more interested in why it can't be done in some simpler way. Do I need to use offsets to raise the spindle?
- Thank you received: 4153
2 years 5 months ago #300091
Replied by rodw on topic Error in tool_offsetview.py
I have not read the whole thread but you may be able to borrow a trick from the plasma setup I worked out years ago. If movement under external offsets and gcode/jogging are mutually exclusive (eg movement is either external offsets or conventional motion, but never both), you can set
OFFSET_AV_RATIO = 0.5 and double the axis velocity and acceleration setings in the ini file. This is how qtplasmac works.
The result of this will be both motion and external offsets will have 100% of the desired velocity and accelleration.
Good luck!
Good luck!
- MarkoPolo
2 years 5 months ago #300845
by MarkoPolo
I have corrected the "brushed_metal_color" style file
Set new gcode style, status warning colors, slider warning colors, fonts...
Time to create page: 0.276 seconds
