- Thank you received: 2181
Error in tool_offsetview.py
2 years 6 months ago #299085
Replied by cmorley on topic Error in tool_offsetview.py
What didn't work with sim_panel?
I used thwsw command after qtdragon started in another terminal:
qtvcp sim_panel &
halcmd net MPG qtdragon.mpg-in sim_panel.MPG-s
qtvcp sim_panel &
- MarkoPolo
- Thank you received: 90
2 years 6 months ago #299086
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
ok, I missed this "halcmd net MPG qtdragon.mpg-in sim_panel.MPG-s"
- MarkoPolo
2 years 6 months ago #299197
by MarkoPolo
I like the "max velocity slider" slider, but it should immediately limit all speeds, including manual movements, but it does not limit manual movements.
I added 4 lines to the handler file, as in the screenshot. Only the first slider setting "MAX_VELOCITY_OVERRIDE" works, I don't know why the other slider settings don't work.
ps. I'm working on a more extensible qtdragon. I will upload the file soon.
It will be possible to stretch it to 4K (3840x3840), it doesn't look very nice at such a high resolution, but it is possible.
2 years 6 months ago #299257
Try adding this function:
def before_loop__(self):
# set defaults lower then max if wanted
DEFAULT_RAPID_OVERRIDE = float(INFO.get_error_safe_setting("DISPLAY", "DEFAULT_RAPID_OVERRIDE", .5)) * 100
ACTION.SET_RAPID_RATE(DEFAULT_RAPID_OVERRIDE)
DEFAULT_VELOCITY_OVERRIDE = float(INFO.get_error_safe_setting("DISPLAY", "DEFAULT_MAX_VELOCITY", 1800))
ACTION.SET_MAX_VELOCITY_RATE(DEFAULT_VELOCITY_OVERRIDE)
The following user(s) said Thank You: MarkoPolo
- MarkoPolo
2 years 6 months ago #299269
by MarkoPolo
Thanks, it works fine this way.
I only changed the settings for "max_velocity_override" so that it took the max speed from the "MAX_LINEAR_VELOCITY" value
FACTOR_VELOCITY_OVERRIDE = float(INFO.get_error_safe_setting("DISPLAY", "DEFAULT_VELOCITY_OVERRIDE"))
DEFAULT_VELOCITY_OVERRIDE = float(INFO.get_error_safe_setting("DISPLAY", "MAX_LINEAR_VELOCITY", )) * FACTOR_VELOCITY_OVERRIDE * 60
Try qtdragon with the ability to stretch to 3840x3840
2 years 6 months ago #299275
It's v e r y stretchy! I see what you mean about the look of the controls for instance when stretched.
try my rough changes to your changes
Time to create page: 0.360 seconds
