Error in tool_offsetview.py
2 years 6 months ago - 2 years 6 months ago #299280 by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
It's hard to find a perfect solution, these empty spaces aren't the best either. I only have a 2560 screen, if anyone has a 4K screen, please try it, I'd love to see such a screenshot. In fact, I don't think anyone uses 4K screens for the machine. I don't see any side effects, so such a high resolution is not a problem.
Last edit: 2 years 6 months ago by MarkoPolo.
2 years 6 months ago #299281 by tommylight
Replied by tommylight on topic Error in tool_offsetview.py
I have a 4K that does not get much use since i got a 34" ultrawide, so i might make some time to test it, so what would that entail?
2 years 6 months ago #299439 by cmorley
Replied by cmorley on topic Error in tool_offsetview.py
I pushed a sim to master to test the MPG work.
Its in sim/qtvcp_screens/qtdragon/qtdragon_mpg.ini
It has a sim MPG loaded automatically
2 years 6 months ago #299450 by MarkoPolo
For me, "qtdragon_mpg.ini" does not run the "sim_panel" panel, but if I run it manually, it works. The changes in the highlighted frames work, the normal axis direction buttons do not work, maybe additional pins need to be added, or something... It would be best if someone could tested with real MPG.
Are you going to introduce a more flexible qtdragon?
If so, I'll work on the details, if not, I won't waste my time. I think it's worth it, because it has no negative impact on current resolutions, and maybe it will be useful to someone.
2 years 6 months ago #299451 by cmorley
Yes I will push your work. do you wish me to wait for your next mod ?
2 years 6 months ago #299453 by cmorley
Are you using an installed version of linuxcnc or a compiled?
Time to create page: 0.290 seconds
