- Thank you received: 90
Error in tool_offsetview.py
- MarkoPolo
2 years 5 months ago #299469
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
I use the installed version, but I also have a version compiled on a virtual machine.
You can push it, but I think it will take 2-3 days to send a more refined version.
- MarkoPolo
2 years 5 months ago #299491
by MarkoPolo
There are problems (quite critical) with the pause and the spindle stop and lift function.
1. If I pause the button, the spindle will rise and stop, but if I resume operation from the keyboard (pause or spacebar), the program resumes operation but does not start the spindle and will not lower it down. (I use "at speed" speed control)
2. If I resume operation and press pause again relatively quickly (about 0.5-1 sec before the spindle spins up to the set speed), the spindle will stop spinning but the machine continues to work with the spindle turned off.
- Thank you received: 2181
2 years 5 months ago #299529
Replied by cmorley on topic Error in tool_offsetview.py
I forgot about the pause key binding - that should be easy to fix.
I see the repause problem here and will work on the fix.
Thank you.
Thank you.
2 years 5 months ago #299568
Ok pushed a fix for pause problems and your last qtdragon ui upgrade.
- MarkoPolo
2 years 5 months ago #299617
by MarkoPolo
I am uploading the corrected qtdragon.ui file. There are no major changes, but there are a lot of changes that improve the better fit of the elements and more proportional stretching.
I tested the keyboard pause problem a lot and generally everything works as it should. But it sometimes happens that problem number 2 from the previous post still occurs. This happens very rarely, so I run this command from the console and it works much more often. "halcmd setp qtdragon.external-pause 0 ;sleep 1.738 ;halcmd setp qtdragon.external-pause 1" . It seems that the problem with pressing the pause button occurs when the spindle reaches full speed and just before it starts moving. Then the spindle stops and the machine starts moving. This effect was also observed in a simulation on a virtual machine.
2 years 5 months ago #299653
Ok pushed some more fixes to qrdragon and your ui changes.
Time to create page: 0.343 seconds
