- Thank you received: 90
Error in tool_offsetview.py
- MarkoPolo
3 years 11 months ago - 3 years 11 months ago #257830
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
I am using version Python 3.7.3
Last edit: 3 years 11 months ago by MarkoPolo.
- MarkoPolo
3 years 11 months ago #258004
by MarkoPolo
- Thank you received: 2181
3 years 11 months ago #258070
Replied by cmorley on topic Error in tool_offsetview.py
Yes I was hoping it was related to python version. I test with a newer version then you.
3.8.10.
I'm still not sure why you have a problem but I do not.
3.8.10.
3 years 11 months ago #258096
could you try changing the line 110 to :
source = source.decode("utf-8", "ignore")
see if that helps?
see if that helps?
- MarkoPolo
3 years 11 months ago #258107
by MarkoPolo
Yes, when added to line 110 "ignore" , it works without error.
Maybe it's actually a python version problem if you're using 3.8.10
3 years 11 months ago #258111
could be in new versions 'ignore' is default. Thanks for testing I'll push that fix to 2.9
The following user(s) said Thank You: tommylight, MarkoPolo
Time to create page: 0.151 seconds
