- Thank you received: 90
Error in tool_offsetview.py
- MarkoPolo
4 years 2 months ago - 4 years 2 months ago #249611
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
not much is happening, so I made some minor adjustments in the setup tab, because the buttons didn't look right.
Two other problems:1. With manual movements of the A axis, the "fast/slow" switch does not toggle the value.2. In the "setup" tab, the link to local files in lcnc installed in the virtual machine works normally, but on a normal computer this link does not work for me, I cannot find the reason. Does it do the same for you?
Marek
The problem with the "fast / slow" switch fixed, I am sending an updated .ui file
Marek
Marek
Marek
Last edit: 4 years 2 months ago by MarkoPolo.
- hottabich
- Thank you received: 96
4 years 2 months ago - 4 years 2 months ago #249613
by hottabich
Replied by hottabich on topic Error in tool_offsetview.py
To switch in the designer, you need to add a signal slot or an attached file. linuxcnc installed in computer.
Last edit: 4 years 2 months ago by hottabich.
- MarkoPolo
4 years 2 months ago #249616
by MarkoPolo
"Fast / slow" switch problem fixed, sent updated .ui file
After pressing the link "local files" are computer files displayed to you?
- hottabich
4 years 2 months ago #249632
by hottabich
Yes. After pressing the link "local files" are computer files displayed.
- MarkoPolo
4 years 2 months ago #249635
by MarkoPolo
hi Chris
I see that you changed the ui file, but I think something went wrong, because after the update there are no changes, the "fast/slow" switch does not work.
In the handler file, the sizes of the buttons from the setup tab are changed
Marek
Marek
- hottabich
4 years 2 months ago #249645
by hottabich
Please open the pdf file. And with the attached handler as well. How will be better?
Time to create page: 7.345 seconds
