qtdragon - probing issues
3 years 5 months ago #270759 by rodw
Replied by rodw on topic qtdragon - probing issues
Ok Versby seems unchanged from prior behaviour :)
Basic Probe incorrectly finishes at z clearance + extra depth
See attached image Z is at 13mm when it should (and was previously) be 10mm
You need the extra depth becasue if you probe to surface and finishes at Z10
on an XY corner probe the probe only decend to the surface height before probing for the material. Adding extra depth ensures the probe contacts the edge instead of potentially skimming over the top.
Because each probe routine is a python procedure, It might be possible to add a checkbox to basic probe "Probe to height first"
If set,  a corner or edge probe could probe for the height before probing for X & Y.
That would let you zero the machine in one step (and is consistent with a normal workflow)
That would be cool!
3 years 5 months ago #270761 by cmorley
Replied by cmorley on topic qtdragon - probing issues
So the only change I did was separate xy and z max probe distance. You can have them at different lengths.
This doesn't have anything to do with finish position.
Can you confirm that max Z is being honoured now
finish depth:
I see in the code, extra depth is always added to clearance, but when down probing I think it shouldn't. extra depth does make sense when down probing.
extra depth is to get below chamfers etc when side probing.
Does that sound right?
3 years 5 months ago #270763 by cmorley
I pushed a change to not add extra depth to down probe.
This should fix the finish position to be Z clearance when finished.
3 years 5 months ago #270764 by rodw
finish depth:
Yes I reckon you got it right. I guess on a side probe it has to lift up from it's position by extra_depth + clearance height to get to the finish (clearance height)
But on a straight down Z probe, it is already at surface height when the probe triggers so it just needs to lift by clearance height.
I think if the extra height adjustment has been removed from the Z probe, it's safe to push it to 2.9 branch now.
It will be a while before I'm back at work again.. Might not be until Monday (your Tuesday).
Great to have nailed one more bug! Thanks for being so responsive!
3 years 5 months ago #270765 by rodw
could not help myself. Went back to work. Now working wit h flying colours.
Where is the .ui file for the basic probe panel?
3 years 5 months ago #270770 by cmorley
share/qtvcp/widget_ui
github.com/LinuxCNC/linuxcnc/tree/master/share/qtvcp/widgets_ui
the help files re there too.
Time to create page: 0.325 seconds
