qtdragon - probing issues
3 years 5 months ago #270775 by cmorley
Replied by cmorley on topic qtdragon - probing issues
Can you pull again and test. added better logging and error messages
It's quite a big change so careful testing.
3 years 5 months ago #270802 by Roguish
Replied by Roguish on topic qtdragon - probing issues
Nice to see qtdragon probing is getting some attention.  thanks.
found another problem, i think.   in  Versa Probe option.
seems the Outside probing of a boss (the center option on the Outside probing type page) does not report the results correctly.
See the image.
the Inside probing does report results correctly.  see the image.
I was probing the inside and outside diameters of a bearing.  first the inside, then the outside.
I looked around the best I could to find the problem, but can't tell exactly where or what it is.
I check in probe_routines.py. probe_subprog.py, and versa_probe.py.   and looked through probe ngc files......
please check it out and fix if possible.
also, what is the functional order of the code?  like when one clicks on a probe type routine, what is actually going on in the program?
3 years 5 months ago #270803 by cmorley
ui button sends probe function name to versa_probe.py
versa_probe sends function name/data to probe_subprogram (running as a sub process)
probe_subprogram imports probe_routines so really both files are one program.
versa 'inside hole button' calls 'probe_xy_hole' in probe_routine
probe_xy_hole does all the probe moves and calculates diameter
versa 'outside hole button' calls 'probe_outside_xy_center'
probe_outside_xy_center doesn't calculate anything it calls other separate function.
The following user(s) said Thank You: Roguish
3 years 5 months ago #270804 by Roguish
so, can the poor, incorrect reporting for the Outside pocket be fixed?
it's not 'Outside Length', it's an Outside boss.....
please?
thanks for the program functioning path....
3 years 5 months ago #270806 by rodw
Replied by rodw on topic qtdragon - probing issues
Was that image probing for a boss or a pocket/
If a boss, why is it reporting an inside hole?
I really have not had any luck with small holes (eg 10mm). There are non-probe moves happening after the probe enters the hole that cause an error. Really there should be  no non probe moves inside  a hole.
I wonder if the boss shouldn't be using top, bottom, left and right side probing?
3 years 5 months ago #270807 by cmorley
I pushed a hopeful fix to the feature branch above if you can test...
Time to create page: 0.308 seconds
