- Thank you received: 4153
I thought you'd know how. I don't think your shortcut will work. There are other significant changes to probing in that branch and a lot more files than a .ui and handler have been touched. If you are using sebs Debs, there are not many dependencies to install. configure should list them. Just copy the list to a text editor, clean up the list and install them. It would be good to have another tester.. I feel lonely.....I have done RIPs for many years, but not on my current mill.
I just copied the 2 files, and will test 'em by replacing the current files with the new copies. should work since it's a .ui and a .py, not compiled.
Agreed. This is an amazing interface already.gotta keep at this. it took a bunch of years for axis to get worked out.....
