qtdragon - probing issues
- Roguish
- Thank you received: 31
09 May 2023 14:49 - 09 May 2023 15:11 #271030
by Roguish
Replied by Roguish on topic qtdragon - probing issues
Chris, where are you putting these changes? git branch ????
If I recall correctly, I can just do a 'git pull' to update, then the compile only compiles what has changed.....
Last edit: 09 May 2023 15:11 by Roguish.
- Thank you received: 2181
09 May 2023 17:02 #271041
Replied by cmorley on topic qtdragon - probing issues
git pull
git checkout qtvcp_probe_max_z_fix
The following user(s) said Thank You: Roguish
- Thank you received: 4149
09 May 2023 19:30 #271060
Replied by rodw on topic qtdragon - probing issues
Yes, unless you do a make clean, only changed files are built by make. Because the changes are only to python and .ui files, they don't need compiling so a make finishes up immediately but I always run it just in case.Chris, where are you putting these changes? git branch ????
10 May 2023 03:02 #271080
Chris,
I worked this out. Inside probing works correctly if X & Y hints are entered,
If hints are not added it goes a bit crazy for no reason, See the screen dump and video
photos.app.goo.gl/SgRoQ9yWaFavzKNB9
There really is no valid reason to do what its doing.
It should never move away from the face to be probed on an inside probe
It should not move towards an already probed surface.
10 May 2023 10:27 #271097
Great information - thanks Rod.
well here is something interesting:
If you don't add a hint, because of the math, the distance can become a negative value.
The python function expected the value to always be positive.
The first MDI command adds a negative sign, so you end up with two negative signs.
And linuxcnc happy accepts two negative signs, and converts them to a positive number.
And that is why it went the wrong direction on the first move.
I can add error checks for length hints.
10 May 2023 12:11 #271101
so a case of two wrongs don't make a right
This just came to me.
Assuming the direction is positive towards the desired surface to probe (whatever sign that is).
Perhaps if could be solved as follows:
if the calculated start position was negative in relation to the physical start position (eg further away), then the move is truncated by that distance and the current position is deemed the start position.
That should eliminate the initial wrong way move...
Sorry gone cross-eyed writing asciidoc for getting Linuxcnc.... Hope the above makes sense
10 May 2023 12:13 #271102
I suspect this also explains why I could not probe small holes...
- Roguish
10 May 2023 14:43 #271108
by Roguish
Chris and Rod,
well, looks like it's getting better.
What ever the outcome is, please, please include good documentation so users know what to do, and what not to do. Probes are expensive.....
10 May 2023 21:21 #271132
Could you write a small sample of how the docs would be most helpful for use?
There are help files but they probably lack detail.
11 May 2023 11:59 #271158
Replied by andypugh on topic qtdragon - probing issues
Does this probing system revert to machine units before probing? I just published a fix to probe-screen-ng related to this.
Time to create page: 0.296 seconds
