qtdragon - probing issues
- JohnnyCNC
- Thank you received: 115
14 Jun 2023 21:36 #273553
by JohnnyCNC
Replied by JohnnyCNC on topic qtdragon - probing issues
Thanks Rod,
I do believe that it has the Baytrail chipset. That name sounds familiar. I will focus a bit on the hardware side to make sure (as best I can) that the USB connections are good. It may be time for me to switch to the ODroid H2 and 7i76E I have on the shelf. Right now I am using a 6i25+7i76 with the J1800.
- Thank you received: 4141
15 Jun 2023 00:18 #273561
Replied by rodw on topic qtdragon - probing issues
The H2 will likely need the R8125-dkms driver installed to improve latency with the mesa network segment.
I have a H2+ on Bullseye here
- JohnnyCNC
15 Jun 2023 00:43 #273562
by JohnnyCNC
I just looked up my order and mine is also an H2+. Do you run a fan on yours? I have a fan on mine but in desk testing it only comes on at a low speed if at all.
15 Jun 2023 00:46 #273563
no fan here.
- Roguish
- Thank you received: 31
18 Jun 2023 15:06 #273783
by Roguish
Replied by Roguish on topic qtdragon - probing issues
Jim, thanks for the explanation. I admit I did not fully read it until today.
That would be really good to include in the documentation.
And, actually, maybe include the calibration work in the Versa Probe screen and code......
Chris, this is for you too.....
- Vector
- Thank you received: 27
21 Aug 2023 21:20 #278651
by Vector
Replied by Vector on topic qtdragon - probing issues
I just want to express my awe, intimidation and appreciation for what you all are doing in this thread in particular as well as and in every other.
You don't get a big enough audience for your brilliance. Thank you!
The following user(s) said Thank You: Roguish, tommylight, rodw
Time to create page: 0.185 seconds
