qtdragon - probing issues
06 May 2023 19:24 #270809 by cmorley
Replied by cmorley on topic qtdragon - probing issues
I really have not had any luck with small holes (eg 10mm). There are non-probe moves happening after the probe enters the hole that cause an error. Really there should be no non probe moves inside a hole.
That is the edge length move (in versa) you need to make it smaller for small holes.
Check out the help button on versa. I made the images bigger in the feature branch
The following user(s) said Thank You: Roguish, rodw
06 May 2023 19:24 #270810 by Roguish
Replied by Roguish on topic qtdragon - probing issues
will do.
I use Seb's buildbot2 debs.
your fix should be there in a day or two.
I will keep an eye on it. checking the 'changes' that show up here...
buildbot2.highlab.com/debian/dists/bulls...uspace/binary-amd64/
06 May 2023 19:27 #270811 by cmorley
I haven't pushed it to any real branch. I won't merge it till it's tested a bit.
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
06 May 2023 19:33 #270813 by rodw
Replied by rodw on topic qtdragon - probing issues
git pull
git checkout qtvcp_probe_max_z_fix
should do it
No Rougish. Cmorley was referring to this test branch. so it won't be in sebs Debs until we test
Just do a RIP install.  If you have not done that befor, let me know.
git clone github.com/LinuxCNC/linuxcnc linuxcnc-dev
cd linuxcnc-dev/src
make -j4
sudo make setuid
.cd .../scripts
. ./rip-environment
linuxcnc
If you have any custom components, you need to rebuild them in the RIP environment
06 May 2023 20:05 #270814 by Roguish
the first set of data are correct for the inside diameter of the bearing that I was probing.
the second set is incorrect. I probed the outside of the bearing using the center icon thing on the 'Outside' page, and the data given in the Status is that for an 'Outside Length'
06 May 2023 20:15 - 06 May 2023 20:33 #270815 by Roguish
I have done RIPs for many years, but not on my current mill.
I just copied the 2 files, and will test 'em by replacing the current files with the new copies. should work since it's a .ui and a .py, not compiled.
well.  not going to work.   way too many modified files.....I'll just way until it's all pushed.
Last edit: 06 May 2023 20:33 by Roguish.
  • rodw
  • Platinum Member
  • Platinum Member
06 May 2023 20:35 #270817 by rodw
I thought you'd know how. I don't think your shortcut will work. There are other significant changes to probing in that branch and a lot more files than a .ui and handler have been touched. If you are using sebs Debs, there are not many dependencies to install. configure should list them. Just copy the list to a text editor, clean up the list and install them. It would be good to have another tester.. I feel lonely.....
06 May 2023 21:11 #270819 by Roguish
I'll think about it..... it's definitely better to have more than 1 tester.....
06 May 2023 21:57 #270825 by Roguish
well, trying.  but no luck..  won't compile
not sure what your line   'make -j4'  is doing.
I get error   'Makefile.inc must specify RTPREFIX and other  variables.  stop.'
also looking at:  linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
  • rodw
  • Platinum Member
  • Platinum Member
06 May 2023 22:15 #270827 by rodw
drop the -j4 if it's a problem. All it does is specifies the number cores when compiling to add a bit of speed (eg multiple threads run instances of compile). Maybe you don't have a CPU with 4 cores. It worked for me yesterday  :)
The Docs are very good so follow them and you should be right.
If it helps I grumbled a bit when I had to do a RIP on my mill too.
Ethercat was failing until I copied the .so file to the correct RIP folder and I had to compile a couple of custom components.
Time to create page: 0.179 seconds
