- Thank you received: 7491
Rods "Spaceship" Scratch built Plasma Cutter build
6 years 3 months ago #176796
Replied by tommylight on topic Rods "Spaceship" Scratch built Plasma Cutter build
We would not be embarrassed to watch it at all !rodw wrote: ............ I'm too embarrassed to share!
- bevins
- Thank you received: 338
6 years 3 months ago - 6 years 3 months ago #176806
by bevins
I'm going to have to read this thread/book of yours one day...
Replied by bevins on topic Rods "Spaceship" Scratch built Plasma Cutter build
Last edit: 6 years 3 months ago by bevins.
- Thank you received: 4153
6 years 2 months ago #178699
Replied by rodw on topic Rods "Spaceship" Scratch built Plasma Cutter build
Well I bought a small accessory for my plasma cutter at an online auction which got delivered on Monday.
Then they poked it under a vehicle hoist
and extended the boom and placed it right against the back wall!
I even scored a bonus pallet of tooling which was not in the listing.
This is a 2.0 metre, 50 tonne Amada press brake with NC control. Its been retrofitted with a Presstek touch screen 2-3 years ago and there was a business card for the guy that did it on the machine so he's been helpful. It was also fitted with light guards at that time which replaced an old guarding system so there are a lot of spare wires floating around in the control panel... It was only a mile or so from work, so I figured I'd never get a cheaper one.
I saw it powered up before I bought it but they disconnected it before I saw it after the sale. The power connection was not easy to find so its taken a while to sort it out but I have an electrician booked tomorrow. There is some dodgy mains wiring in the cabinet that I will get cleaned up while we are at it. It was never wired in according to the manufacturer's directions so I'll get the power away from the logic.
Amada also have been very helpful. He said he wanted to get me to upgrade my spaceship to his laser!
So hopefully this does not end in tears tomrrow!
- machinedude
- Thank you received: 312
6 years 2 months ago #178708
by machinedude
Replied by machinedude on topic Rods "Spaceship" Scratch built Plasma Cutter build
hard part is out of the way now
getting it in the building is most of the battle the rest is just time consuming
keep your fingers out of the way that machine will most likely do some damage
6 years 2 months ago #178719
Send it back, it has fingerprints all over the screen !
Very nice.
Very nice.
6 years 2 months ago #178738
Thanks, it will be pretty hard to get fingers in the way I think as its got all the latest light guards right across the front from the yellow box on the left.
I think the hard part will be putting the shop back together and tidied up! It took a bit to clear the way for it. Once I work that out I'm going to take the spaceship off its wheels and probably bolt it down somewhere in front of it.
machinedude wrote: hard part is out of the way now
Time to create page: 1.264 seconds
