- Thank you received: 4153
Rods "Spaceship" Scratch built Plasma Cutter build
tommylight wrote: Send it back, it has fingerprints all over the screen !
Very nice.
Yeh I saw that in the photo after I posted it.. Hadn't noticed before!
- thefabricator03
- Visitor
thefabricator03 wrote: Nice little franna you have their Rod, you getting into the crane game
I am sure that press will pay for itself pretty quickly.
Yeh, they put my name on it just for that job. The Semi Driver worked with me in the past and welded up the Spaceship frame for me. I had no clue he worked with that company..
I'm still scratching my head about how to use the press.
- thefabricator03
- Visitor
We made a bench that was level with the bottom die that we rested our brackets on. As the press is upward pressing its hard to get the blade to align with your marks so using the back stop is necessary for any kind of accuracy.
thefabricator03 wrote: The machine I used the NC control only set the back stop. The depth of stroke was set by a rotary dial on the left and side of the machine. We had marks on the dial for common materials.
From what I can gather, this machine has a servo motor fitted there on the left hand side so the stroke should be under NC control. I found the manual and it refers to there being an optional motor available which this one has.
The Ikon controller is 6 axis and only 2 are in use. If you take the cover off you could almost swear it was made by Mesa! Of course my mind is racing wondering how hard it would be to add servos to the backguage height and sideways position adjustments.
- Thank you received: 7491
It had a single servo motor for adjusting the "length of bend" and a smart mechanical switch to adjust the stroke that would move up and down so the other electrical switch got triggered by it.
