Rods "Spaceship" Scratch built Plasma Cutter build
6 years 3 months ago #173653 by phillc54
I always use me old mate Pythagoras to calculate that. :)
6 years 3 months ago #173654 by rodw
tommylight wrote: A small-ish issue there, if you were jogging the machine on that video, set the Display and Traj section max_velocity at 25 to 50% more than each individual axis in the ini, that way it will not limit the X and Y axis speeds while jogging both of them at the same time.
Thats a cool idea Tommy. You might also notice the corners were rounded off with nice chamfers becasue I had no G64 settings. The poor old Chinese NEMA 34's couldn't keep up but the Sany Denki's seemed fine...
phillc54 wrote: I always use me old mate Pythagoras to calculate that. :)
Pythagoras is a cool dude. I forgot about him for years but now I'm playing with Linuxcnc he keeps popping back into my life!
6 years 3 months ago #173657 by tommylight
I said 25 to 50% as most of the time while testing the X and Y do not have the same max velocity, so i leave it at 50 to be safe.
After setting them both to the same velocity, 41.42% should do just fine.
6 years 3 months ago #173670 by Clive S
Phill I didn't realise you was that old.
6 years 3 months ago #173701 by phillc54
HaHa, sometimes I feel that old...
  • thefabricator03
  • Visitor
  • Visitor
6 years 3 months ago #174348 by thefabricator03
Replied by thefabricator03 on topic Rods "Spaceship" Scratch built Plasma Cutter build
rodw wrote: And for the record, a good solid table like the spaceship, handles those sort of numbers in its stride. No stripped belts and no screaming balls!
You see a lot of those aluminum extrusion tables wobble themselves apart at those speeds. I dont care what anyone says, a proper made steel table is hard to beat!
Time to create page: 4.292 seconds
