- Thank you received: 7491
Rods "Spaceship" Scratch built Plasma Cutter build
Oh good, almost had a heart attack there .rodw wrote:
tommylight wrote: Please tell me those are not daisy chained ground wires, please please pleaseeeeee.
Nah, they are in a star to a common ground.
- Thank you received: 4153
tommylight wrote: Yeah, but that will bring the motor closer to stalling, by a lot.
maybe not, elsewhere they say
So pick your figures and you can still get motor rated torque when not accelerating and +30% when accelerating
Do the Sanyo Denki's quote max current or RMS (effective )current do you know?
Lam can claim all those things as they are sure their drives are by far the best at what they do, so where a normal motor wired to a normal quality drive will heat less as the speed goes up, motors wired to Lam will heat more at speed, and that is due to very fast switching and reaching the rated current at any given speed.
Thinking about it, the LAM version of lowering the current after acceleration seems very smart for plasma use, the biggest risk of stalling is while accelerating, so that makes sense. My idea of boosting current is much more suited for mills and stuff with bigger forces in use.
tommylight wrote: Oh i did try mine at 6m/s/s and the result was interesting to say the least, max velocity at 24m/m the machine started moving when changing direction, like the whole machine was moving a little (1 to 2cm) back and forth over the floor, everything was shaking and it did not last to do a video as it started ripping the teeth on the small belts !
Had to change both belts and set it back at 1.5m/s/s.
I wondered about that. Sounds like you came up against the limitations of Linuxcnc's trapezoidal acceleration profile. I think it will need jerk limited (S curve) profiles to support those numbers... but my pinion teeth might be a bit stronger
