- Thank you received: 312
Rods "Spaceship" Scratch built Plasma Cutter build
- machinedude
6 years 4 months ago #171698
by machinedude
Replied by machinedude on topic Rods "Spaceship" Scratch built Plasma Cutter build
i was wonder about how to do field power or more what others were doing. Din terminal blocks with jumpers work too or at least that was how i solved the problem. the mesa option looks like a compact solution and better probably.
The following user(s) said Thank You: joekline9
- Thank you received: 4153
6 years 4 months ago #172302
Replied by rodw on topic Rods "Spaceship" Scratch built Plasma Cutter build
Some small projects seem to attract Murphy!
I bought 5 Sanyo Denki 60mm x 60mm stepper motors for $100 from ebay when they sell for $200 each. Then I had to find some wiring harnesses for them. They finally arrived. So a few days ago I thought I'd fit the easy one up so I pulled off the pulley and drilled it out to an 8mm bore and enlarged the mounting holes on the motor.
Very shortly afterwards I found out that the Sanyos had a different mounting pitch on the bolt holes to a normal NEMA 23 and it did not fit!
I never really got my little Seig SX3 set up after relocating it from home to my workshop and I had a bit of work on it so I could use it again.
Friday, I dug out the CAD drawings and redesigned the mounting plate. Then I went up the road to buy 1 metre 60mm x 6mm flat bar material when I only needed 60mm of it! While I was there, I bought an offcut of 6mm aluminum plate so that next time I can cut out mounting plates and spot the drill holes..
Anyway after drilling and tapping 8 holes in my 60mm square of Ally, its back together.
I guess that one advantage of building your own machine. You can upgrade it.
This is quite massive compared to what was on it before
The old motor was 1.9 Nm (269 oz/in) and the new one is 2.7 Nm (382 oz/in). It will be interesting to see if I get any better performance once I get my machine back together with the Lam drivers.. So now I have to work out how to fit one up on the Z axis!
- thefabricator03
- Visitor
6 years 4 months ago - 6 years 4 months ago #172305
by thefabricator03
Replied by thefabricator03 on topic Rods "Spaceship" Scratch built Plasma Cutter build
Now Rod, you do remember that anything to do with CNC plasma cutters is not suppose to be easy dont you :laugh:
Last edit: 6 years 4 months ago by thefabricator03.
- Thank you received: 7491
6 years 4 months ago #172312
Replied by tommylight on topic Rods "Spaceship" Scratch built Plasma Cutter build
Nema 23 = 56mm frame, Nema 24 = 60mm frame !
6 years 4 months ago #172315
Yeh but NEMA24 does not normally have a 50mm bolt hole pitch. The NEMA24 ones I looked at had the same pitch as the Nema 23 but a different diameter locating flange.
I can't wait to get this turning!
tommylight wrote: Nema 23 = 56mm frame, Nema 24 = 60mm frame !
6 years 4 months ago #172318
I am not that lucky, all the Nema 24 i have have different pitch, just enough to not fit at all !
Time to create page: 0.158 seconds
