Rods "Spaceship" Scratch built Plasma Cutter build
6 years 4 months ago #172447 by rodw
Well, this is what happens when you play with your machine. I found there was some tight spots on the X axis and when I had a look at it, I tightened up all the bolts holding the rack and linear rails and found one missing mounting bolt on the rack which I replaced.. I guess it was time to do some maintenance,
Then I found the X axis pinion shaft I made was quite loose with worn bearings so I spent the afternoon stripping down the pinion and ended up ordering another Flange bearing which is coming via airbag from Perth on the other side of the country. I was missing the correct retaining nut on the old one which is probably why it came loose and wore.
I don't think I totally fixed the tight spots but its a lot better now.
Then I went looking for a NEMA 24 mounting bracket to upgrade my Z axis. I finally found one and it looks a lot better than what I had. Except its 100 mm wide and it has to fit on a 60mm wide backing plate so an adapter is in order. Nothing is easy! Anyway, this is coming via DHL..
www.aliexpress.com/item/32969053665.html...1.0.0.4d634c4dGW7sFL
And I am so impressed with these Sanyo Denki motors, I bought out what was left so have another 15 coming. They just had no idea what they were really worth! (Or where to buy the wiring harnesses possibly!)
  • Moderator
  • Moderator
6 years 4 months ago #172485 by tommylight
rodw wrote: And I am so impressed with these Sanyo Denki motors,...
Welcome to the club ! :)
6 years 4 months ago #172673 by rodw
Well, this turned out alright after it was powder coated.
I've got a bit of wiring to do. before I can get it installed. My replacement FFK12 flange bearing arrived today too so I can also put the X axis pinion back together.
  • Moderator
  • Moderator
6 years 4 months ago #172710 by tommylight
Yummy ! :)
6 years 3 months ago #173357 by my1987toyota
Replied by my1987toyota on topic Rods "Spaceship" Scratch built Plasma Cutter build
well rodw since you took the the time to check out my machine I decided to reply in kind. That plasma table looks fantastic . Well done.
6 years 3 months ago #173385 by rodw
my1987toyota wrote: well rodw since you took the the time to check out my machine I decided to reply in kind. That plasma table looks fantastic . Well done.
Well we Toyota drivers have to stick together regardless of where we are in the world! I'd like to think this thread will get interesting again!
Finally this afternoon, I got the wiring pretty much done and I'm hoping my mate Chris will have time to give me a hand to refit the control box to the table tomorrow.
This box weighs about 17kg now. The wiring is just temporary and I'll have to disassemble it before it all comes together.
But finally, we have power lights on the Lam drivers! 90 volts wow!
A little bit tidier now
Just in time to becasue these arrived today as well
A NEMA 24 mounting bracket is also here so I can upgrade my Z axis with a Sanyo Denki motor. But to do that, I need my table back working again as I have to design and cut a mount for it.
Time to create page: 0.202 seconds
