The 7i49 converts the resolver AC waves into a square wave encoder signal basically. It's handled with discreet logic at the board level. AFAICT linux CNC doesn't know the difference between encoder types at the signal processing level.ok but the driver is controlled by 7i49 via analog output? linuxcnc receives feedback from the resolver in order to give the appropriate output via the card, that circuit is not very clear to me in the sense that if we compare it with an encoder, some scale must be entered, so I wonder if it is a similar tuning as with the encoder, I think, as it has to enter the encoder scale, there should also be a resolver scale, or not?
The 7i49 actually passes the resolver angle digitally in to the driver as a number. The HAL driver converts that to a numerical angle and simulated encoder counts (but not, at any point, into a quadrature signal)
