Mazak Micro Slant 15 Retrofit
4 years 6 days ago #255150 by tommylight
Did some more reverse engineering yesterday, so not much left to figure for the axis drives, although one might be dead as i wrote here last time i turned it on about a year ago (first mice attack that i was not aware off) it did show that on screen, but when i programed in the parameters (not fun at all) at one point in time it did not show any errors, hence i would like to have a go at [strike]burning[/strike] them...hmm .. testing them! :)
Some more hieroglyphs attached ...
4 years 6 days ago #255151 by Masiwood123
ah ti misevi, ne znam koliko deluju oni visoko frekventni uredjaji za rasterivanje, mada je sad i kasno, dobro je da si dosta stvari spasio, motori ce proraditi;) i dobro je malo odmoriti uz neke druge probleme, toga bar ima svuda i uvek:) ...ako ti sta treba od mehanike samo javi, tipa klizne staze vretena ose, manji dc motori ..toga imam.
4 years 5 days ago #255154 by Masiwood123
this in the picture is surgery, and i believe it's not fun xD. the first thing that stings my eyes.. is the aversion to these eprom`` batteries, whatever machine i imported, either didn't have it or it leaked
4 years 5 days ago #255210 by tommylight
Yeah, no more batteries!
Wired the spindle encoder today, it still works despite plenty of bitemarks on the cable.
Went in (inside the machine) to remove the Z axis resolver, unscrewed the coupling, and it does not let go. Tried as much force on as i deemed OK on both sides, still would not budge, so in a moment of infinite wisdom i though to open the tacho lid and see if i can bolt the encoders there, ... oh the horror! There is a circuit board full of electronics, plenty of wires, what looks like 6 hal sensors (4 pins each, so not sure) as they are arranged in a round shape with metal in between them and a rotating part on the motor shaft. All this shock triggered some memories, on the X and Z drives there is a switch with letters P 0 V , they are set at P, so gussing it is in position mode, now confirmed by the above.
There are some markings on the connectors that added to the confusion as they clearly state AG or analog ground for the +-12V pins (all AG and IG pins are grounded, same with shielding, in total there are 4 separate grounds/0V on the machine).
The only thing left is to add 3 more power supplies, 2 for +-12V and one for 24V, wire one drive and one of those tacho/pickups and see what hapens. Dealing with analog stuff would imply using arduinos, i think i still have some ESP32 with 12 bit analog resolution, hoping i do not have to go that route.
I wonder, when will it finaly hit me that it is enough and just plop some Gecko drives and be done with it.
Not yet, not yet.... :)
I did mention before, i am a persistant piece of $hit! :)
The following user(s) said Thank You: Masiwood123
4 years 5 days ago #255219 by Masiwood123
kod nas se to kaze svaka cast! mislim da bi pored sve krize morao da kupim nove motore, ti si sigurno imao zivce za jos teze stvari ,pa ti je ovo sad igra:), najgore je sto ako odlucis da prodas, svako ko nezna koja je muka, recice skupo``
4 years 4 days ago - 4 years 4 days ago #255275 by smc.collins
Hard to see from here, but are these DC servos ?? if so, whats the power rating ? I aks because I have 2 yaskawa DC tacho feedback cdmr 055k2 drives just sitting here. They are IIRC .5kw
Last edit: 4 years 4 days ago by smc.collins.
Time to create page: 0.309 seconds
