5 Axis ParPort Stepper Setup with RTCP
4 months 3 weeks ago #346913 by marq_torque
Replied by marq_torque on topic 5 Axis ParPort Stepper Setup with RTCP
Hello Andypugh,
This modification was really helpful in last machine I made. I'm now trying to achieve similar but Linuxcnc has changed a alot. Also changed a lot in kinematics. I tried to modify kinematics as per this thread but as expected it's failing with errors.
I want to use XZ and B axis with TCP along with tool length probing. Setup in this thread is working in older version.. I'm struggling to getit worli with Debian 13 rt 2.9.8 Any help or suggestions would be appreciated,
4 months 3 weeks ago #346962 by grandixximo
Replied by grandixximo on topic 5 Axis ParPort Stepper Setup with RTCP
Build errors? Can you share your current code? Not many people will have the time to read 10 pages of an 8 years old thread...
Be more specific about what you are struggling with.
The following user(s) said Thank You: marq_torque, andrax
4 months 2 weeks ago #347040 by marq_torque
Pardon my brevity,
Here is detail
I'm trying to compile this kinematics file "5axiskinsN.c" and getting this error
cnc@cnc:~/linuxcnc/configs$ sudo halcompile --install 5axiskinsN.c
Compiling realtime 5axiskinsN.c
Linking 5axiskinsN.so
objdump: section '.rtapi_export' mentioned in a -j option, but not found in any input file
/usr/bin/ld:5axiskinsN.ver:2: syntax error in VERSION script
collect2: error: ld returned 1 exit status
make: *** [/usr/share/linuxcnc/Makefile.modinc:124: 5axiskinsN.so] Error 1
4 months 2 weeks ago #347043 by marq_torque
Ok, I found my one mistake. i was trying to compile "5axiskin.c" but it didnt work so after reading more, I found there is "userkins.comp" file need to be compiled. so i edited file as per attachment and getting error as per screenshot.
File Name: userkins.comp
File Size:8 KB
4 months 2 weeks ago #347080 by Aciera
Replied by Aciera on topic 5 Axis ParPort Stepper Setup with RTCP
1. As you have already found out 'halcompile' will not work with all .c files. A 'run-in-place' (RIP) installation would be required here.
2. .comp files have their own syntax, so you cannot simply copy-paste the code from a .c file into a .comp file.
4 months 1 week ago #347274 by marq_torque
Hello Aceiera,
Can you help modifying this Kinematics which I can compile as .comp file, I'm Total noob to understand RIP installation.
Any documentation or guide, for RIP in 2.9.8.
Thanks in advance
The following user(s) said Thank You: ANDY$TARK
Time to create page: 0.326 seconds
