TCP 5-axis kinematics
- jsskangas
- Thank you received: 9
17 Jun 2019 18:53 #137144
by jsskangas
Replied by jsskangas on topic TCP 5-axis kinematics
Mine is fully working 5-axis switching kinematic machine.
I use M128 and M129 user M command to switch TCP on/off.
- jsskangas
17 Jun 2019 18:58 #137145
by jsskangas
Hello 3D-Master
Machine zero is machine zero and you should not change its place, for that you have G54-G59 zero points.
You need to zero machine with index pulse from encoders.
this way you will get correct machine zero.
then you always know where your rotary center is and you can use parameters to tell to kinematics.
Zero point can not
Zero point can not
- pl7i92
- Thank you received: 358
18 Jun 2019 15:42 #137200
by pl7i92
Replied by pl7i92 on topic TCP 5-axis kinematics
on a 5 axis there is only the tool length that cananges
there is no part zero
as the postprocessor refers to mashine ZERO
thats the same as G54
X center C table G53 eq G54-G59
SAME on Y
Z is ON MY MASHINES calibrated to 100mm from AC hight
the TOOLs are Mesurerd against this to the AC
A is horizontal with -15 +95 WAY movement
C is zero to a precise switch and the encoder Index
so all is only one coordinate there is NO part Touch off AT all
partzero is Bottom MID point
if you use a 4Axis G-code eighter A is fixed to Zero or 90 deg depending on part
i use a Different Config depending on part
SAME on Y
- 3D-Master
- Thank you received: 5
18 Jun 2019 21:07 #137230
by 3D-Master
Replied by 3D-Master on topic TCP 5-axis kinematics
@pl7i92
of course 5 axis machines have Part zero
also Machine zero is not the same as G54, because G54 is the part zero.
"X center C table G53 eq G54-G59" Only if the machine zero is at the center of rotation AND you have set G54-G59 without offset.
this way you are limited to "having to perfectly align a part respectively to the CAM part", which we want to avoid.
@jsskangas
yes, what i ment was to use parameters from the .var file to dynamically change the center of rotation point. The machine zero might be just slightly off the real center of rotation point so the part will be inaccurate to a degree. So you could probe the real center of rotation, feed the X,Y,Z values to the .var file and the kinematics module will read those values. I think this is what industrial controllers like Heidenhain do. Also if it is possible to do it like this, you could set the machine zero at Z-Max or wherever you want to.
I hope you understand what i mean
@jsskangas
- jsskangas
18 Jun 2019 21:18 #137231
by jsskangas
This is the case. my machine zero is far away from rotary center.
My machine zero is at tool change position and following parameters will tell kinematics where rotary center is located.
setp XYZBCsmkins.X-rotpoint 102.8505
setp XYZBCsmkins.Y-rotpoint 0.0968
setp XYZBCsmkins.Z-rotpoint -455.3930
Also zeropoint used in operation can be set to part.
with this kinematics zeropoin does not need to be located in rotary center.
The following user(s) said Thank You: 3D-Master
- 3D-Master
18 Jun 2019 21:49 #137232
by 3D-Master
i have not actively followed this thread, does switching kinematics now work when rotarys are not at zero? Also this is for 2.8 right? can you change the centerpoint position values on the fly without restarting the machine? could you maybe, when you have time, upload the newest machine files?
thanks
thanks
- Hakan
- Thank you received: 454
19 Jun 2019 20:29 #137306
by Hakan
Replied by Hakan on topic TCP 5-axis kinematics
I am also interested in the current status.
Especially around the shifting of kinematics at arbitrary position.
Is that real now?
Is that real now?
- plopes9000
- Thank you received: 18
19 Jul 2019 14:31 - 30 Dec 2019 22:14 #139881
by plopes9000
Replied by plopes9000 on topic TCP 5-axis kinematics
I too have joined the club of getting TCP to work and be practical in LinuxCNC.
I have read this thread and looked at the code/configs of jsskangas and automata/r.lol.
In my view the switchkins approach is sound and its working.
jsskangas approach to include the rotary axis machine coordinates in the kinematics calculations is key to make it practical to use.
Since I wanted to get the latest dev branch, I actually retrofitted the switchkins branch changes into the 2.9pre dev branch.
Key topics:
1) change the switchKins kinematics to take into account the machine coordinates of the rotary axis - see switchKins.c attached.
2) Improve my machine homing precision
This was not straight forward since my servo drive's connector and function to output the zero pulse are busy with the linuxcnc step/dir pulses and I certainly did not want to install additional encoders. I could use a different servo drive connector with 24V step/dir inputs but the frequency limit would go from 1MHz to 250KHz and I would need to fab a 5V differential (mesa 7i76) to 24V single ended circuit. Since I already use CanOpen over Ethercat for the servo drives and that gives me access to the motor rotary position - which is derived from the servo drive known absolute rotary position - I decided to write a small component to calculate the zero pulse.
However the LinuxCNC index homing procedure assumes that the sync is done with an encoder that resets its position and counters upon seeing the zero pulse. For that reason I had to change emc/motion/homing.c to keep using the offsets.
Finally, see attached test gcode file and video.
Key topics:
net :tool-offset motion.tooloffset.z xyzac-trt-kins.tool-offset
setp xyzac-trt-kins.y-offset -0.15
setp xyzac-trt-kins.z-offset -27.59
setp xyzac-trt-kins.x-rot-point 407.565
setp xyzac-trt-kins.y-rot-point 154.229
setp xyzac-trt-kins.z-rot-point -228.1452) Improve my machine homing precision
net x-axis-zero-pulse-zero-pulse x.zero.pulse.zero-pulse <=> joint.0.index-enable
net x-axis-zero-pulse-rot-pos x.zero.pulse.rotary-pos <= lcec.0.EL6751-CanOpen.x-rot-positioncomponent axiszeropulserotposition "generate axis zero pulse from axis rotary position";
pin io bit zero_pulse "generated rotary zero pulse";
pin in u32 rotary_pos "axis rotary position";
param rw u32 deadband=10000 "axis rotary position deadband";
variable u32 old_rot_pos=0;
variable int old_dir=0;
variable int pulse_started=0;
function _;
license "GPL";
FUNCTION(_)
u32 new_rot_pos = rotary_pos;
if (new_rot_pos != old_rot_pos) {
int new_dir=0;
int over_deadband=0;
if (new_rot_pos<old_rot_pos) {
new_dir=-1;
over_deadband=(old_rot_pos-new_rot_pos)>deadband;
} else if (new_rot_pos>old_rot_pos) {
new_dir=1;
over_deadband=(new_rot_pos-old_rot_pos)>deadband;
if (over_deadband) { // skip 'deadband' size jumps in any direction
if (zero_pulse && old_dir && new_dir && old_dir!=new_dir)
zero_pulse = 0;
if (new_dir) { // exclude same reading cases
old_dir = new_dir;
old_rot_pos = new_rot_pos;
}However the LinuxCNC index homing procedure assumes that the sync is done with an encoder that resets its position and counters upon seeing the zero pulse. For that reason I had to change emc/motion/homing.c to keep using the offsets.
case HOME_SET_INDEX_POSITION:
/* This state is called when the encoder has been reset at
the index pulse position. It sets the current joint
position to 'home_offset', which is the location of the
index pulse in joint coordinates. */
/* set the current position to 'home_offset' */
joint->motor_offset = -joint->home_offset;
joint->pos_fb = joint->motor_pos_fb -
(joint->backlash_filt + joint->motor_offset);
joint->pos_cmd = joint->pos_fb;
joint->free_tp.curr_pos = joint->pos_fb;
// PL ++
/* this moves the internal position but does not affect the
motor position */
offset = joint->home_offset - joint->pos_fb;
joint->pos_cmd += offset;
joint->pos_fb += offset;
joint->free_tp.curr_pos += offset;
joint->motor_offset -= offset;
// -- PL
/* next state */
joint->home_state = HOME_FINAL_MOVE_START;
immediate_state = 1;
break;Finally, see attached test gcode file and video.
Last edit: 30 Dec 2019 22:14 by plopes9000. Reason: updated component axiszeropulserotposition
The following user(s) said Thank You: jjdege
19 Jul 2019 15:22 #139886
Replied by andypugh on topic TCP 5-axis kinematics
Do you think this is generalisable? ie are there machine-specific constants compiled in to the kinematics? If it could be considered a generalisable kinematics then there might be an argument for building it in to LinuxCNC.
19 Jul 2019 15:25 #139887
Are you aware that LinuxCNC now supports absolute encoders for homing?
linuxcnc.org/docs/2.8/html/config/ini-co...t__lt_num_gt_section
(HOME_ABSOLUTE_ENCODER)
Time to create page: 0.230 seconds
