- Thank you received: 454
TCP 5-axis kinematics
- Hakan
7 years 8 months ago #125942
by Hakan
Replied by Hakan on topic TCP 5-axis kinematics
That is something that could be really useful! Great work.
- grandixximo
- Thank you received: 410
7 years 8 months ago #126258
by grandixximo
Replied by grandixximo on topic TCP 5-axis kinematics
I've tested your configuration, it's exactly what is needed, thank you!
Only one thing I noticed, before homing the machine it doesn't seem to be possible to move axis C, i haven't looked in depth in the ini or hal files, is this a problem due to kinematics or is it fixable by hal/ini?
If it's not possible to move C before homing it's a major drawback because you can't override limits and get out of them, you would have to change settings to be able to come out of limits.
Tomorrow I'll have a deeper look into the ini and Hal to see if I can fix it from there...
- grandixximo
7 years 8 months ago #126318
by grandixximo
I've looked and can't find anything wrong with the hal or ini file that would prevent C from moving before homing.
this is the error that pops up in the terminal when trying to move
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1544, in __call__
return self.func(*args)
File "/usr/bin/axis", line 2562, in jog_plus
speed = get_jog_speed(a)
File "/usr/bin/axis", line 1761, in get_jog_speed
if joint_type[a] == 'LINEAR':
IndexError: list index out of range
- grandixximo
7 years 8 months ago - 7 years 8 months ago #126328
by grandixximo
I think i figured it out, it's because in the Kinematics B is skipped, so the Axis interface somehow before homing thinks C should be joint 5 (according to X=>J0,Y=>J1,Z=>J2,A=>J3,B=>J4.C=>J5), but joint 5 doesn't exist, the jog pins for joint 4 (which is axis C in your configuration) work fine, it's because the manual switch is not available by pressing shift+4, so the interface before homing is not sure which joint is which axis, it is a bug but not related to the switch, i think the same would happen in master with a similar configuration but without switch.
Last edit: 7 years 8 months ago by grandixximo.
- 3D-Master
- Thank you received: 5
7 years 8 months ago #126719
by 3D-Master
Replied by 3D-Master on topic TCP 5-axis kinematics
how do you tell linuxcnc where the center of rotation of ABC is? can you specify the values in the var file? that would be great because i could correct the center of rotation (with a calibration program) without possibly restarting the machine.
7 years 8 months ago #127096
You can't tell it, and to an extent it doesn't need to know.
It would be useful to be able to do this to get a more accurate graphical preview, but it has no effect on what the G-code does.
In theory it could also be used to convert angular moves into linear feed rates, but I am not sure if any controls actually do that. LinuxCNC doesn't.
Because of this it is better to use inverse-time feed rates when linear and rotary axes are used simultaneously. This needs to be done in the CAM system which _can_ be told where the actual centre of rotation is.
Part of the problem is that this issue simply isn't considered in standard G-code. One interesting solution might be to add a new G-code (G94.1 is available) that defines the rotary axis origin in the current coordinate system. I think that this would be rather beyond the scope of a remapped routine, however.
Replied by andypugh on topic TCP 5-axis kinematics
3D-Master wrote: how do you tell linuxcnc where the center of rotation of ABC is?
Time to create page: 2.737 seconds
