- Thank you received: 9
TCP 5-axis kinematics
- jsskangas
8 years 3 weeks ago #118643
by jsskangas
Replied by jsskangas on topic TCP 5-axis kinematics
Ok, I found error.
Kinematics are ok and switching between kinematics works well.
X axis offset is not supported at the time.
Problem was lost encoder pulses.
Im running 8000 pulses per mm.
This was too much for hardware to handle.
I need to drop my encoder count for this hardware, sadly.
I would have liked to get everything out from machines accuracy.
Im running 6i25 and 7i77, currently Im not using filtering to get better encoder count rate.
I have 8000count per mm but now Im going to drop it down to 2000 per mm.
8 years 2 weeks ago #118684
Replied by andypugh on topic TCP 5-axis kinematics
OK, I wasn't even considering hardware problems....
- jsskangas
8 years 2 weeks ago #118694
by jsskangas
Same here, I had previously 5I20 and 2 analog servocards and 1 io card.
This setups did not had this lost pulses problem.
I still need to investigate more accurately what is going on.
- Stud54
7 years 11 months ago #121480
by Stud54
Replied by Stud54 on topic TCP 5-axis kinematics
Any news here?
Sven
Sven
- jsskangas
7 years 11 months ago #121514
by jsskangas
Hello
Well yes.
It's now working perfectly.
Error was lost encoder pulses.
I'm using 6I25-7I77 compo and it turned out that it's max count rate is ~550 KHz when filtering is on.
I was loosing encoder pulses on rapid moves.
I dropped my encoder count on all axis, this resolved my problem.
I still need to run impeller to test how this affected my surface quality.
Well yes.
- Stud54
7 years 11 months ago #121525
by Stud54
Nice....
How did you home the rotating Axes? Home on index with a separate Ini?
You are German, right?
Sven
Sven
