TCP 5-axis kinematics
8 years 6 months ago #109000 by andypugh
Replied by andypugh on topic TCP 5-axis kinematics
Very nice.
The following user(s) said Thank You: jsskangas
8 years 6 months ago #109001 by jsskangas
Replied by jsskangas on topic TCP 5-axis kinematics
Here is video of blade finishing:
8 years 6 months ago - 8 years 6 months ago #109348 by allwinedesigns
Replied by allwinedesigns on topic TCP 5-axis kinematics
Can anyone explain the changes that were made in LinuxCNC 2.8 that made switching between kinematics modes possible? I'm using MachineKit, which hasn't ported those changes and I'd like to be able to implement enabling/disabling tool center point control as described in this thread.
Last edit: 8 years 6 months ago by allwinedesigns.
8 years 6 months ago #109368 by jsskangas
I think that separation of joints and axes is the one.
Easiest way would be to use linuxcnc instead of machinekit.
There are small powerful motherboards available.
8 years 6 months ago #109396 by andypugh
allwinedesigns wrote: Can anyone explain the changes that were made in LinuxCNC 2.8 that made switching between kinematics modes possible?
I am not sure if the 2.8 changes are necessary for kinematics switching to work. It might work equally well in 2.7 or Machinekit. The cleverness (as I recall it, without re-reading the thread) was in the actual kinematics module.
If you wanted to port the Joints-Axes branch changes to Machinekit I think you would have a big task. It changed just about every file, in major ways.
8 years 5 months ago #111080 by 819132306
Replied by 819132306 on topic TCP 5-axis kinematics
Hello,
jsskangas.
You have switched between RTCP and 3+2 machining modes on LINUXCNC without restarting LINUXCNC.
This is very cool.
I want to construct the following two structures of 5 axis kinematics.
But I don't know much about this homogeneous transformation.
Only the table-table structure is in the linuxcnc help documentation.
linuxcnc.org/docs/ja/html/motion/5-axis-..._axis_configurations
Looking forward to your reply
Time to create page: 0.754 seconds
