- Thank you received: 9
TCP 5-axis kinematics
- jsskangas
8 years 3 months ago #114425
by jsskangas
Replied by jsskangas on topic TCP 5-axis kinematics
new files
8 years 3 months ago #114506
Replied by andypugh on topic TCP 5-axis kinematics
Just to be clear, this thread is you reporting success rather than asking for help?
- jsskangas
8 years 3 months ago #114516
by jsskangas
Hello
Sorry English is not my native language.
I would like to get help testing this latest version.
Problem is axis losing its position, most likely when changing kinematic model.
8 years 3 months ago #114692
Sorry, I have been away from home.
Can you describe: What you do to cause the problem. What you expect to happen. What actually happens?
- jsskangas
8 years 3 months ago - 8 years 3 months ago #114694
by jsskangas
Hello Andy
First look mu kinematic file.(XYZBCsmkins.c)
There are two M128 and M129 command that switch between two different kinematic model.
Switching can be only done in B0. C0. position.
Both kinematic models works as they supposed to.
Problem is that, some how axis or joint loses it's position during sifting between these two kinematic models.
Between several shifts I managed to get 5mm error to X axis.
Problem is not mechanical or HW related.
I have been running lot higher pulse rates(servo encoder pulses) in 3+2 axis works than in 5 axis.
Last edit: 8 years 3 months ago by jsskangas.
8 years 3 months ago #115111
This has been sat in my "to answer" pile for a week, and I haven't managed to find the time to look at it in detail.
It sounds like your forward and reverse kinematics might not give _exactly_ the same result. Have you checked this?
I think it is possible to run the kins function from the command line. But I can't recall how one does that.
Time to create page: 0.223 seconds
