TCP 5-axis kinematics
8 years 10 months ago #102864 by jsskangas
Replied by jsskangas on topic TCP 5-axis kinematics
I need quick help.
Im trying to write out values from kinematics trough HAL pins:
this is located in" rtapi_app_main"
if((answer = hal_pin_float_new("xyzbc-trt-kins.oma",
HAL_OUT, &(haldata->oma), comp_id)) < 0) goto error;
this is in code:
*(haldata->oma) = 11.11;
when looking/watching from HAL configuration in linuxcnc only shows 0.0
it's compiled and im using this file.. and it does not give error when compiling.
Also I tried HAL_IO, HAL_IN no difference.
How can I write values to HAL pins????
8 years 10 months ago #102961 by andypugh
Replied by andypugh on topic TCP 5-axis kinematics
What you have ought to work, but there is a bit more you need too (You may be doing this, but haven't shown that part of the code) One thing is that the haldata struct needs to be hal_malloc-ed
8 years 10 months ago #103064 by jsskangas
Yes if you mean this line:
haldata = hal_malloc(sizeof(struct haldata));
That is located in rtapi_app_main() before introducing HAL pins.
Jussi
8 years 10 months ago #103068 by andypugh
And is oma in the haldata struct (I can't open .rar files to check. (And I am on a Windows 10 PC at work))
Is the code that is setting the oma value in a function that is being used? I am a little unclear which of the forward and inverse kins subroutines get called when. I think I would be tempted to add another HAL pin that changes state whenever forwards kins or reverse kins runs.
8 years 10 months ago #103070 by jsskangas
Ok
Here is c file of kinematics.
8 years 10 months ago #103169 by andypugh
Nothing looks particularly wrong (other that you probably need HAL_OUT as HAL_IO is only for very special and unusual cases.)
Is the haldata->oma pin never changing vale at all? I think that that caon only really mean that that code isn't being run.
Do the print messages etc all happen as expected?
Time to create page: 0.157 seconds
