component compile problem
8 years 6 months ago #109431 by Skidloaders1
Thanks Andy
Unfortunatly
github.com/LinuxCNC/linuxcnc/blob/master...onents/carousel.comp
=> This webpage is not available
Even if i could have downloaded it, not sure where to insert it :(
but we want give up
8 years 6 months ago #109442 by andypugh
Replied by andypugh on topic component compile problem
Odd, the link works for me.
But I have attached the file.
sudo halcpmpile --install carousel.comp
Should install the new version on your system.
(But you will need to figure out your halcompile problems first)
8 years 6 months ago #109493 by Skidloaders1
Tx Andy Link is working now. Halcompile is still not.
must the .comp file be compiled from a specific folder ?
rgds Wilfried
8 years 6 months ago #109500 by andypugh
No, halcompile can be run from anywhere. But the comp file must be in the path from where the command is run.
8 years 6 months ago #109502 by andypugh
a, b = f.split("\n;;\n", 1) ValueError: need more than 1 value to unpack
Seems to show that Halcompile is running, but is not able to split the .comp file into two parts at the ";;" token.
Is it possible that something in your toolchain is inserting DOS or Mac style line endings? it is looking for the character sequence "\n;;\n" which is 0A 3B 3B 0A and (for some reason) is not finding it.
docs.python.org/3/library/stdtypes.html#str.split
It could, possibly, be a localisation issue. Perhaps your system is using . as an item separator and , as a decimal separator? Though this would probably give a different error.
8 years 6 months ago #109796 by Skidloaders1
Thanks Andy for your great "carousel" script.
Only managed to compile some files so far.
HAL component generator examples working =
atanxy.comp - ddt - arraydemo - rand
also
oracchanger.comp from ArcEye
triacchanger.comp from ArcEye
HAL component generator examples NOT working with the usuall errors
out8.comp constant.comp
many others of various sources.
I took working files as an examples - copied and pasted all sort of lines to the ones not working.
rewrote portions etc.. on 3 different machines of mine
still have no clue what's going on
Time to create page: 0.470 seconds
