component compile problem
8 years 6 months ago #109803 by Skidloaders1
Found the problem.
Visited a fellow South African CNC club member , Henk Du Preez.
He compiled carousel.comp from my USB stick - > did not compile
Downloaded file from the net, straight on his machine -> everything went OKI DOKI
Long story short -> I previously installed Google within Iceweasel search engine, because Google is familiar to me.
When I used the Iceweasel search bar instead and downloaded carousel.comp -> compiled ==> :) :) :) :) :) :) :) :)
Wilfried
8 years 6 months ago #109813 by andypugh
Replied by andypugh on topic component compile problem
Well that's odd!
8 years 6 months ago #109903 by Skidloaders1
Good day all
Looks like my problems are far from over
adding to hal file and loading linuxcnc
loadrt carousel pockets=4 ==> no problem
as soon as I add
addf carousel servo-thread ==> file not found
Checked that file carousel.ko is where it is supposed to be -- yes it's there with its mates
note: I did not compile within the proper linuxcnc folder at first.
I noticed that the ____.ko are root files and can't be deleted or overwriten???
8 years 6 months ago #109905 by andypugh
Probably needs to be addf carousel.0
8 years 6 months ago #109917 by Skidloaders1
Thanx again Andy
I will put the 4 pound back in the toolbox ( lol ).
Wilfried
8 years 6 months ago #109920 by PCW
Replied by PCW on topic component compile problem
If you are unclear about function (or pin or parameter) names you can always load the comp and "show" the function(s) (or pins or parameters) that the comp exports
for example:
halcmd loadrt carousel
halcmd show function
The following user(s) said Thank You: Skidloaders1
Time to create page: 0.397 seconds
