component compile problem
8 years 5 months ago #110963 by Skidloaders1
Good day Andy
1)The carousel.0.sense pins do change according to the rotation
2) the carousel.0.active pin is not connected to anything
3) the iocontrol.0.tool-change pin never goes active ( T2 + M6 command )
rgds Wilfried
8 years 5 months ago #110965 by andypugh
Replied by andypugh on topic component compile problem
That sounds like the tool-prepared pin isn't being set after tool-prepare goes high?
8 years 5 months ago #110999 by rene-dev
Replied by rene-dev on topic component compile problem
This is the relevant bit from the weiler lathe andy mentioned.
I hope its the latest version, let me know if it doesnt work.
the encoder inputs are connected according to the original schematic, which also matches the documentation for the encoder.
the reverse and forward you have to try.
loadrt carousel pockets=8 encoding="binary" pty=0 addf carousel.0 servo-thread net tool-num iocontrol.0.tool-prep-pocket => carousel.0.pocket-number net tool-change iocontrol.0.tool-change => carousel.0.enable net tool-changed carousel.0.ready => iocontrol.0.tool-changed net rev1 carousel.0.motor-fwd => hm2_7i92.0.7i77.0.0.output-04#reverse net rev2 carousel.0.motor-rev => hm2_7i92.0.7i77.0.0.output-05#fwd net reva carousel.0.sense-0 net revb carousel.0.sense-1 net revc carousel.0.sense-2 net revd carousel.0.sense-3 net revs carousel.0.strobe net revp carousel.0.parity
8 years 5 months ago #111012 by Skidloaders1
Thanks Andy
Does tool-prepared not mean that the carousel/turret is now in its commanded position?
rgds W
8 years 5 months ago #111013 by Skidloaders1
Thank rene-dev
My carousel(turret) has 4 positions with sense pins at every position.
Turns only in one direction ( hydraulic push - pull ratchet system) see video above somewhere
encoding = single ( I believe)
regards W
8 years 5 months ago #111014 by Skidloaders1
Good day Rene-dev
My Weiler lathe must be a older unit i guess
anno early 1980's ( still a solid and accurate unit - super over designed )
Time to create page: 0.167 seconds
